Dual tank switch removal
'84 K20, Want to change out the dual tank switch on dash. What's the procedure of extracting the switch?? Pry it out? Doesn't seem to be easy access to the back of the switch. Thank You!
Re: Dual tank switch removal
It just snaps in. There are some springy tabs that hold it in place, you need to compress those from the back side.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
The 77's were bolted in from the back side
My '77 did not have a dual tank switch. I got one for a later model, and I cut the correct hole in the dash to match.
It snaps in with plastic tabs, but I have never been able to get it out in a truck with A/C without removing the dash pad. The A/C ducts block off access to the rear of the switch. The switch and cover plate are about $20, so if you snap it off from the front you can buy a replacement which can be installed from the front without accessing the back.
my 79 had has speed nuts on the back. either way I would get up there with a phone or something and take a pick or feel around to be sure
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
