Project Heaven in my 67!!!
Need opinion on whether to buy or shy away...
Got an offer to buy a 2001 2500hd with 6.0 LS and 4L80E trans(2wd) its cheap $400. Problem is the drive train has 241K on it and was used as a service truck. The engine is burning oil pretty badly but otherwise seems to run ok once it is hot. It came into my shop because the transmission cooler line was leaking oil and he wanted it repaired and wanted me to look at the engine oil consumption issue. Pretty sure valve stem seals are toast. But, with 241K on the clock this thing could use a complete overhaul.
Would you buy the truck to pull the power plant out and use in a 67 SWB (obviously once its been overhauled)? |
the boat guy
Re: Need opinion on whether to buy or shy away...
All day every day.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
If you've got the room, the engine and trans core plus scrap are worth that alone.
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
What the others said, at $400 it's worth more than double that in scrap and parts.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Buy the truck, take what you want off of it and part out and scrap the rest. You should be able to make back your $400 easily.
Good luck, Nick |
![]() Join Date: Dec 2013
Your a mechanic and your not sure what it's worth standing next to it ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
I'm Not sure he was asking worth as much as he was asking opinions on purchasing the drivetrain for use in a 67 truck. That is just how I read it
You sir would be correct. I understand its value, just not sure the 6.0 is the right choice for my 67. Would I be better off to look for a 5.3 for it?
High hump or low hump cab? 4L80 is BIG ala TH400. Personally, it's all about the transmission. If it were me, I'd be looking for something with the 6 speed trans behind it. What's worth more, your time or your money?
But for $400 seems like couldn't go wrong. Throw some rings and valve seals in and see what happens. But back to time/money where is the break for you?
4L80e will fit a low hump 67-72 cabs with engine on stock towers and Dirty Dingo slider mounts.
Unless you're that concerned about the gas milage get the 6.0/4L80e combo. You've got the most potential for power with the bigger displacement and the toughest trans. The 6spd auto will improve milage mostly around town, once you're cruising on the highway there's no real difference in mileage between the two transmissions.
Get it, strip, overhaul it, install it.
Science flies you to the moon; Religion flies you into buildings. LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/ |
#13 |
Sweet! Thanks guys just wanted to make sure that my thoughts on dropping the 6.0 into the 67 weren't misguided! Now to make it work!
#14 |
Go for it, then feel welcome to help me do the same ;-)
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
#15 |
