EFI Fuel Tank other than Boyds
I'm planning on running a 5.3L motor from a 04 Suburban in my 67 Suburban. Has anyone else used an off the shelf fuel tank and sending unit? I just read that someone used a gas tank from a 90 Wrangler and sending unit from a 87 GMC pickup in a 70 Chevy pickup. Just wondering if anyone has done the same with a Suburban.
I know most people go with the Boyds tanks. They look REALLY nice but they want $1000 for the tank with sending unit that I'm looking at for my Suburban. That is just out of my price range right now. Thanks, Nick |
![]() Join Date: Sep 2015
Re: EFI Fuel Tank other than Boyds
I'm using a 32 gallon fuel tank out of an 89 Blazer in my suburban, it has the baffles and uses a cartridge style fuel pump in the sending unit. Should be able to find them in the local scrap yards, rockauto also sells them new.
I read somewhere about there being a cartridge style fuel pump that would work for the 5.3 swap, I don't remember what the part number is though. I'll do some digging and see if I can come up with a part number. Edit: Walbro 255 I believe is the one I was reading about.
1996 Chevrolet K1500 (daily runner) 1969 Chevrolet Suburban K20 "Solomon Grundy" *Click for build thread!* Last edited by ChopsawSurgeon; 10-21-2016 at 01:13 PM. Reason: Adding info |
#3 | |
The Older Generation
I bought a new off the shelf stock type tank for my Panel Truck and it worked great. It has the return line port and a vent port if you want to use it. I used a Walbro external pump and a Corvette filter/regulator. Mine is a 5.7 LS1. There is a lot of info on the "LSX Swap" Forum on here.... LockDoc
Thanks Leon I appreciate the help.
#5 | |
From Rock Auto, it looks like the tank with sending unit is $200. Then add a Walbro pump and I should be into the setup for about $300. Nick |
I'm using a '90 Suburban tank. It's not quite bolt in but the fabrication to make it work isn't difficult.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#7 | |
Looking at it, it looks like it's the same tank, says Rockauto.com. Not bad $233 plus a new tank maybe. It looks like the 90 Suburban tank is 40 gal and the 89 Blazer tank is 31 gallons. Maybe the Blazer tank will be a little smaller and won't hang down as much. Eventually my truck will be fairly low. Thanks, Nick |
#8 | ||
Thanks, Nick |
My application is a K20.
Supposedly the 40 gallon tank I am using is deeper than the 31 gallon Blazer tank.
Thanks for the pic Dave. I appreciate it.
I don't have mine permanently mounted yet, still working out some kinks, but it looks like I have somewhere between 7-8" drop from the bottom of the frame rail to the bottom of the tank.
1996 Chevrolet K1500 (daily runner) 1969 Chevrolet Suburban K20 "Solomon Grundy" *Click for build thread!* |
#12 | |
Thanks, Nick |
#13 |
