Carrier bearing
![]() I have a 1974 chevy pickup and I obviously need a new carrier bearing or support bearing.. Not sure what the difference is.. But I am sure which one to pick.. It is my daily so I cant just take it apart and have it un drivable. I'm not too familiar with this kind of stuff. https://www.summitracing.com/parts/tmk-hb88508a I found this item. Will this item be fine? Last edited by Steven37; 10-20-2016 at 04:03 PM. |
Re: Carrier bearing
You should be able to get the same one at a local parts store for around the same price. I'd fix it before driving too much, if it comes apart it will cause lots of damage
-Cody |
Re: Carrier bearing
It looks shifted out of alignment, but it could be just the picture. I'd check rear suspension and engine/ trans mounts to make sure all is happy
-Cody |
Re: Carrier bearing
#5 | |
Re: Carrier bearing
![]() Join Date: Jun 2016
Re: Carrier bearing
Got mine at Autozone. Mine was a *tight* fit on the driveshaft. I had to find a piece of pipe to drive the new one on.
Re: Carrier bearing
Re: Carrier bearing
http://www.autozone.com/drivetrain/d...61_4959_10434/
Found this cheap one from Autozone that's in stock at my local autozone.. Will it be as good as the $30 one though? |
#9 | |
Re: Carrier bearing
Less than $20.
![]() Make sure you measure your driveshaft. For my '87, there were 2 possible diameters for the inner bearing. |
Re: Carrier bearing
Ya it looks ok. I think I was looking front to back, but backwards. I think. Haha. The last one I bought was around 20-30$ at Napa if I remember right
-Cody |
Re: Carrier bearing
Sometimes these "steady bearings" can be a real pain to remove. I had to carefully use a cutting torch to remove the last one I did. The inner part of the bearing was seized on the driveshaft.
