Old 10-20-2016, 08:42 PM   #1
Ghost's68
Ghost's68's Avatar
Need help ID'ing Ford rear brakes
Hey guys so I'm about to get ready to lower the truck again after installing the ECE drop kit, all new brake parts, and completely re-doing the front steering. I'm looking at the rear end brakes and would like to swap out the rotors and brakes since it's torn apart.
I have no idea where and what the Ford 9"rear end came from. Can some one help please. I'm going to try and do some research also but figured I would ask you guys as in sure I'll get quicker help. I wasn't able to measure a rotor since I ran out of time.
Here's some pics. Thanks
Ghost's68 is offline   Reply With Quote
Old 10-20-2016, 09:30 PM   #2
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
Re: Need help ID'ing Ford rear brakes
Looks like an aftermarket rotor of some sort and an early 80's Toronado rear caliper. Does the caliper have the parking brake integrated into it?
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 10-20-2016, 11:22 PM   #3
Ghost's68
Ghost's68's Avatar
Mike
Im pretty sure this is a kit of some sort. I went out and looked at the calipers a bit more and the calipers are held on by a welded bracket attached to the tube. The welds are NOT factory.
Old 10-21-2016, 12:11 AM   #4
70SBC10BOB
70SBC10BOB's Avatar
They look like GM metric calipers. They were used on the front of mid-size gm cars. Just pop out the pads and match them at a parts store. If I remember they were used starting mid 80s.
1970 C 10 A work in progress!!
70SBC10BOB is offline   Reply With Quote
Old 10-21-2016, 09:28 AM   #5
B. W.
B. W.'s Avatar
X2 - they look GM, there should be casting #s on them, a competent parts guy (gal) can reference them
B. W. is offline   Reply With Quote
Old 10-21-2016, 11:49 AM   #6
Ghost's68
Ghost's68's Avatar
I believe the calipers won't be to hard to get brakes for. I'm really at a loss for the rotors. These appear to be a two peice design and need that hat part that bolt to the caliper as well as the tube flange?....
Old 10-26-2016, 12:02 AM   #7
70SBC10BOB
70SBC10BOB's Avatar
The rotors should be available at any race shop (not speed shop) that sells rotors to late model dirt or asphalt cars. They usually have 8 mounting bolts most of them are the same. You will need to know the diameter 11.75 or 12.19. And the thickness .75, 1.0 or 1.25. Slide the hats off, unbolt the rotor, assemble in reverse order. I would also use new grade 8 bolts and safety wire. It is not that big a deal.
Good luck.
