10-21-2016, 04:17 AM | #1 |
battery cut off switch.
I have a question I Just got running my 1972 k10 with a 5.3 ls and right now its my DD but I want to put a kill switch but for now I just want to put a battery cut off switch like the ones that run off the negative wire off the battery but since I have a 5.3 LS EFI do you guys think it will mess up the main computer for the motor?
[ATTACH][/ATTACH] |
10-21-2016, 08:01 AM | #2 |
Re: battery cut off switch.
It shouldn't be an issue, the computer should hold memory when the battery is disconnected. The LS is used in a bunch of racing applications that require the battery shut off switch. We run them on all of our LS engines, I'd recommend one for anyone with a vehicle that might sit for any time. The one I mainly use is the Allstar Performance unit, works great and never had an issue with one.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
10-21-2016, 10:00 AM | #3 | |
10-21-2016, 12:30 PM | #4 |
I put an LS3 in a Camaro and it had some parasitic small 1W drain somewhere, so I had to unplug the battery when parked for more than a day or two, and so it always got reset, and it never bothered it.
I don't doubt there are fuel trims and so on that would be handy to have kept, but it learns them again fast enough it seems.
10-21-2016, 12:39 PM | #5 | |
Yeah My fear is that when I park it and hit the switch that when I come back to the truck that the computer will be reset and right now the truck runs good, my tuner tune my truck almost to the max before i have to run bigger injectors, So i don't want to lose the tuner and the truck not to run right. |
10-22-2016, 01:22 PM | #6 |
I have seen a disconnect with a by-pass wire for retaining the memory of electronics,but I don't remember where. Maybe google could help?
David |
10-22-2016, 06:49 PM | #7 |
Way back in my mechanic days, when computers first came out on cars if we changed a battery out, the computer would lose all memory and settings. To combat this, they came out with a simple plug that plugged into the cigar lighter and a 9 volt battery on the other end. This maintained enough juice while the battery was disconnected. Dont know if this might help in your situation but it might if a cut off switch causes problems.
10-23-2016, 01:22 AM | #8 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
