Old 10-22-2016, 12:28 AM   #1
oliver415
Will this setup work
Hello im looking to put a 350 sbc with a t56 tranny in a 68 lb c10
What problems would i run into if i went with this setup? Im still new to this so dont be mean if the question sounds stupid. Thanks. Right now it has a 307 and powerglide in it. I just wanna know if the setup i want will work and if it does what parts should i look out for when buying the tranny
oliver415 is offline   Reply With Quote
Old 10-22-2016, 02:51 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Will this setup work
Try posting this in the 67-72 board section
Old 10-22-2016, 07:25 AM   #3
Moved your post for you. I keep thinking about the same idea, but for my 64. It will be interesting to see the responses.
Old 10-22-2016, 08:02 AM   #4
FL71C10
I think the T56 uses a hydraulic clutch system. That might take some figuring.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 10-22-2016, 08:10 AM   #5
Grumpy old man
Grumpy old man's Avatar
Yes , Guys have already done it , Get out your wallet .
Just to start ...
bell housing
clutch,pressure plate ,throw out bearing ,pilot bearing
shifter
clutch pedal and complete linkage
trans mount
drive shaft and yoke
floor shift steering column
manual flywheel
correct starter
speedometer correction
I'm not sure if you need the high hump for clearance ,This short list will get you started . search the forum for instructions and do your homework before ripping into it . with all the parts sitting on the floor its a weekend job . https://shiftsst.com/
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 10-22-2016, 10:19 AM   #6
LongBox
Personally, I'd be looking for a parts donor vehicle, one that was a manual trans, floor shift truck to begin with. That way, you might luck into a lot of the parts, and possibly be able to sell what you don't need to help pay for the project.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
