My 72 6 point oh LS swap
Hey fellow builders
Figured I'd post up what I'm doing on my 72 GMC, to get some input/ideas. I see a lot of you guys are way past this point. Lots of beautiful work in this forum. And, I've learned a ton from the great reads. Thank you all. Anyway My build: '72 GMC - Fresh6.0 LQ4 @ 11:1 Fresh 4L60e with corvette servos and all the cool doo dads Boyd welding 19gallon fuel cell Comp Cam - Mutha Thumper Polished crank 706 heads with Alex springs All sensors are new LSX Industries built my harness, and programmed my ECM Headman mid-length headers Champion 3row radiator with two 14" fans Shark guages Trick Flow steam tube kit Taylor 10.4 wires Lokar gas pedal Lokar 23" floor shifter w/boot ... And ALL of the other stuff that's needed, fuel line/connectors, engine mounts, trans mount, prepping, ETC... ![]() Truck is a full frame off resto and was painted a factory 2000 sunset gold (?) color. Most every nut and bolt has been changed. The 350 and TH350 are coming out within the next couple of weeks, since now I have (most) everything to start the swap. More to come... |
| Bookmarks |
