10-22-2016, 09:03 AM | #1 |
17 inch rallys??
Anyone running the 17 inch rallys on a 66 style truck? Ive been thinking about it and tire size options?? Thanks for any info you can provide.
10-22-2016, 10:48 AM | #2 |
Re: 17 inch rallys??
Check out the ALUMINUM Rallys at Year One!
10-22-2016, 11:05 AM | #3 |
Well, what tire are you running now? What are your plans to do with truck? Towing? Assuming a 235/75/15 = 28.8" and a 235/55/17 =28.1" start there. Goto a tire store or look on line for brand, load capacity, and other sizes.
I run 245/45/18 front and 295/45/18 rear. 26.6 and 28.6" tall.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
10-22-2016, 01:46 PM | #4 |
Still in the build process it has 15s on it now with 2.5 drop spindles and 2 inch drop springs so im thinking my a arms are to low (scrub line)??? It will be a driver when done and i do want a hitch on the back. Thank for the info!!
10-23-2016, 10:18 AM | #5 |
What are you running for rear shocks? Maybe a set of 'progressives' would help during tow trips. Looks like fleeBay has some wheels; lmc is no help.
1994 C1500 rclb 1988 C1500 rclb 1969 ES5500 B E A S T 1983 C10 'farm truck' 1976 K20 Suburban 1984 K10 Suburban 1981 Jeep CJ5/350 Vortec 1941 Dodge WC18 Ambulance 2000 GMC Bus (parts warehouse) |
10-24-2016, 05:30 AM | #6 |
Monroe just for mock up on the rear. Any pictures of 17 inch wheels on our trucks guys?
10-24-2016, 07:21 AM | #7 |
I am also tossing around the idea of trying a set of the new rallys. Im looking into the 18s though.. Just wanna do staggered and cant find a tire size I like yet. Guess Im picky..
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
10-24-2016, 11:24 AM | #8 |
These are 18x8 and 18x9 with 245 45 18 front and 285 45 18 rear. I was going with a 295 45 18 for the rear but found an amazing closeout deal on a pair of Pirelli's 285 45 so I'm going to run them for a while.
10-24-2016, 03:56 PM | #9 | |
Can you tell us who makes the wheels and what BS you have? |
10-24-2016, 04:17 PM | #10 |
17x8
4.5 front/5 rear drop with 275/55R17 in the rear and 275/50R17 up front Last edited by forestb; 10-24-2016 at 04:25 PM. |
10-24-2016, 05:58 PM | #11 |
10-24-2016, 06:32 PM | #12 |
Yep im liking what im seeing!!!!!
10-24-2016, 08:47 PM | #13 |
Verdel how much is your truck dropped? I like a lot! I love the thoughts of 285s out back. Did you have to modify anything else?
10-24-2016, 10:21 PM | #14 |
Be careful when buying 17's the tires are much more expensive than 16's or 18's because it is a rair size.
10-24-2016, 10:33 PM | #15 |
I have 2.5" drop spindles up front with the torsion bars cranked down a little but not sure the exact measurement. I simply adjusted them to the height I wanted. Same thing for the rear air bags. No modification was needed at all. I actually run it a little lower than the height on the pics...hope this helps
10-25-2016, 07:18 AM | #16 | |
10-27-2016, 07:20 AM | #17 |
Anyone else care to share there big rally wheels??
