10-22-2016, 05:51 PM | #1 |
Trouble with LS plates
Hello guys ran into a problem here with these LS swap plates by Pol Performance "adjust2fit". The kit plates doesn't seem to fit to the original engine mounts as it's too wide. Has anyone had this problem or used these plates? Not sure if I'll need new mounts which I'm sure I will. I got these plates from "Brothers Trucks". Thank you guys in advance! I apologize for the pictures for the odd angles.
10-22-2016, 06:02 PM | #2 |
Re: Trouble with LS plates
Looks like youre trying to double mount them, putting a mount on a mount. You need some kind of stand for your new mount to bolt to, not another mount.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-22-2016, 06:14 PM | #3 |
ls1nova71 thank for pointing that out to me, the guy at brothers told me it was just a simple bolt on with no modification needed. Do you know of any stand? Thanks again.
10-22-2016, 07:20 PM | #4 |
I would imagine that POL makes stands for them, and then it would be a simple bolt in deal.
10-23-2016, 09:22 PM | #5 |
measure the mount width illmeasure my ls stands see if its what you need ill send pictures later
10-24-2016, 12:48 PM | #6 |
Looks like they are intended for their tubular engine mount brackets
Here's a link to their mount systems. https://www.performanceonline.com/19...engine-mounts/
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 10-24-2016 at 12:54 PM. |
10-25-2016, 04:12 PM | #7 |
With those style mounts on your frame, I would just use Car Shop 1" setback plates. CSP2370 is the part number for the ones I use, buy them on ebay. You just take the clam shells off your engine and bolt them to the adapter plates, then drop in. Haven't had an issue on the several swaps I've done.
10-25-2016, 06:53 PM | #8 |
damn now im going to have to go check mine. i have the same kit. i ordered on e bay
1967custom |
