![]() Join Date: Jan 2012
60 gmc charging issues
So, I've replaced the battery with an exide agm, had the generator rebuilt and replaced the starter.
If I charge the battery up with a charger, it will start. If I boost it from another vehicle, it will start. If I drive it for a while, it doesn't have enough juice to turn over the 305 v6. Thoughts? I want to say it's the external voltage regulator, but I'm not sure how to test that theory. Thanks for any tips or ideas! |
Re: 60 gmc charging issues
Do you have a voltmeter? The charging system test involves the use of a voltmeter, a wiring check and "full fielding" the generator to see if it it makes electricity.
I do have a voltmeter.
Posted via Mobile Device |
You may need to polarize the generator. I believe its done by briefly touching a jumper wire between the battery terminal and one of the other terminals. Not sure which terminal though. Its been 30 years since Ive had a generator in a truck / car but had them in a few Harleys that I owned. Every time I had the generator out, it had to be polarized or it would not charge.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#5 | |
