Old 10-22-2016, 10:49 PM   #1
Clavo106
new engine mount q's.
327 engine...c10 ..Bought some new engine mount at my local auto parts store. (Anchor) nothing was wrong with my old ones just had this engine off for a yr and was installing today with the new mounts.. my problem is that a line everthing up but the center bolt just get snug i try tightening some more then just releases. Is this norm? Its does this on both mounts... I just got it snug and throw in some lock tite. But thing I should replace them with the old ones...any idea s.
Clavo106 is offline   Reply With Quote
Old 10-22-2016, 10:53 PM   #2
ecna
Re: new engine mount q's.
My new mounts were threaded for metric in that center hole.
ecna is offline   Reply With Quote
Old 10-22-2016, 11:20 PM   #3
Clavo106
I went back to the auto parts store to check that out with a 10mms since I had none.. with a new mount they had there but the 10mms did not fit. And the 3/8 did.. I had no tools.. people stated this in the other threads as well about the metric difference...can of lam since I just installed it.. just to pull it out..
Old 10-23-2016, 12:23 AM   #4
randy500
I'm pretty sure that hole is not 3/8-16, it's 7/16-14
randy500 is offline   Reply With Quote
Old 10-23-2016, 03:42 PM   #5
garyd1961
Did you chase the threads in the mount before installing them? Mine were full of rubber flash.
garyd1961 is offline   Reply With Quote
Old 10-23-2016, 04:22 PM   #6
72bowtiestepper
You are correct....7/16-14
72bowtiestepper is offline   Reply With Quote
Old 10-23-2016, 04:32 PM   #7
Clavo106
Thanks guys. I took it out first thing this morning. And tryed tightening it with it out with the 3/8 but it bottom and kept spinning... so I chased it out with a 7/16 tap and ran a 7/16 bolt and it got tight. Problem fixed...engine mounts installed now with 7/16 bolt.. I did tap with a 3/8 tap before I installed it the frist time. And I did try a 7/16 bolt but the bolt didn't want to go in.. o well got fix that's all I care about.. thanks for the help..
Old 10-23-2016, 07:30 PM   #8
davepl
davepl's Avatar
In case others hit this, I too wound up with reproduction mounts that had too-long, metric center bolts. Had to cut them down so they didn't punch into my block, and no idea why they're metric, but...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
