My Barn Find GEM. What do I need to do to get her on the road?
Hi all, happy to say that I just purchased my 4th 67-72, and its by far my coolest yet. This is the most original truck I have ever seen, no rust whatsoever anywhere, and no dents on the body AT ALL (original paint).
A couple points i need advice on, firstly, if i am going to wash away that layer of white chalky oxidation is that going to damage the paint? how can i protect that original color? How do i find out which engine it has (cubic inches) also its not running, i obviously need to change the fluids and gas, but how about the transmission oil or differential oil? I bought this truck for 4500, in the San Francisco bay area. Think that is a fair price for something this original and straight? thanks for the help everyone! |
Re: My Barn Find GEM. What do I need to do to get her on the road?
Also, is this just going to take a 12 volt battery or are some of these 6 volts?
Roadtrip!
![]() Join Date: Feb 2003
Nice score! I would just give it a soap and water bath to start with and see how it looks.
These are all 12v systems.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Nice truck, they are all 12 volt.
For the paint. One loft the Xperia will know how to get the "chalky" stuff off and not hurt your paint. I think they use CLR, because it'll clean, but not damage, and stop the rust.
Change all your fluids. Even if they look"ok". With the moisture and temp changes where you are, condensation will build up in the fluids. Change your points, plugs and wires, taking note what they look like when you take them out. Also do a complete inspection, and change out of your shoes, drums and brake cylinders, and change your brake fluid. Check the casting numbers on the block for the size. Tires, change them, as the rubber breaks down an belts will separate and the worst possible time. If you do the work yourself, for about $500 you'll be safely on the road, and the envy of many.. ![]() I hope that one day I have your kind of luck finding such a truck. |
You basically bought the 1967 GMC version of my truck.
![]() That is a 250 straight six engine. You can tell by the fuel pump being closer to the front of the engine than it is on the 292. I hope you keep it all original, there are not many stepsides and even fewer with the spare tire on the side. |
![]() Join Date: May 2001
Nice find, if it was running when parked it should run again. Do you know why it was parked, and how long ago?
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
As far as the paint, it looks to nice to use CLR on just yet. Start with Dawn dishwashing detergent and hot water. May need to really scrub it 2 or 3 times to get the aged dirt off. Once it is clean you can tell more about the paint. I would think a good rubbing compound followed by a good wax would make her shine.
Long as i have it, will absolutely keep it original. no bull**** with this one, id like to keep it that way. Will use clr in certain places, and i plan to use #7 on the body, or at least read up more before i touch it.
was parked for 15 years, not sure why, but hoping it will run! Also the tires look brand new and hold air well, is it ill advised to drive on those after 15 years? |
WOW, your so lucky!!
Roadtrip!
Hope you get it running, I don't think I would chance tires that old.
#12 | |
![]() Join Date: Jan 2007
1. soapy wash and then rubbing compound. for the surface rust spots i like clr and 0000 steel wool, it may take a thin amount of the green paint off, leaving the black primer (check out the first post of the tiffany thread). i like the look of it. i don't like when people shoot clear over it, it just doesn't look right. a good waxing occasionally is the best way to preserve it (imho) and keep it looking original. the paint lasted 48 years, it should last a few more. 2. i think you got info on the engine, to be sure you can check the casting on the side of the block (pass. side above the starter i believe on I-6's). 3. defer to others on the mechanical advice. 4. $4,500 is a good deal for that truck in this area. i wouldn't say you stole it, but it's a good deal. you don't come across them very often in that condition, congrats on the find!
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#13 |
Congrats on a great find, and a great price. Extremely nice truck. Agree with the decision to preserve it, rather than mod it or rod it.
Make sure you do not run any old gasoline through the pump, carb and engine. It could very well varnish up things like the little valves in the pump, the jets in the carb, and the valve stems. As for the tires, if they are dry rotted, you can usually tell by looking carefully on the sidewalls and in the tread grooves. You will see fine cracks and checking. But, if they are 15 years old, and you plan to drive it, buying new just makes good safety sense.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
#14 |
nice looking truck! im sure it will be treated perfectly and well enjoyed.
as for the tires, is it the end of the world to run them? no. alot of people do. but this is a high risk, low reward situation. tires do not hold up over time. as stated before. you run a risk of blowout causing costly damage to your gem of a truck , or worse, to you or somebody else from a tire failure while driving. also, not that people always listen, dot regulations state you can not run tires older than 7 years old on the highways. (this could be state -state variations but a general standard to my knowledge) and can actually get you a ticket if you are pulled over. not often do they if you are not a semi, but still can. keep us updated on this great truck
1972 GMC C20 Custom Camper 350/TH350 |
#15 |
![]() Join Date: Apr 2008
Great score.
#16 |
Thanks for the advice everyone, will keep you updated, hoping to get it running this week!
#17 |
Do not run 15 year old tires. Just don't. Maybe you'll get away with it, but they're waiting to blow up on you... If you never drive more than a few miles or over 35 or 40 MPH, maybe.
My Blazer has a folded-over left rear quarter from the tire that separated at 55 MPH. That was one of 4 blowouts I had between my motorhome and my Blazer on the cross-country trip from hell. I did a lot of research after that, and I highly recommend getting new tires. It's relatively inexpensive insurance. I won't run anything older than 6 years from date of manufacture now. |
#18 |
![]() Join Date: Apr 2005
Nice score
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#19 |
This stuff was amazing 30 years ago, though I haven't tried it since:
https://smile.amazon.com/Turtle-Wax-...rds=color+back It removes the oxidation and take you down to rich color in a single step, but you MUST then wax it to preserve it or it'll oxidize quickly again in a week or two. But to get down to the color, it must do it chemically rather than with abrasives, because it's no real work. And get new tires!
