10-09-2003, 02:49 PM | #1 |
Steering column getting the best of me!! HELP
Ok, I have replaced my turn signal cancel cam, cancel springs, and the stupid stupid *&!?!**(&% signals will still not turn off by themselves! Im just waiting for someone to assume that just because I have my blinker on, Im actually going to turn, and then clobber my truck! Any suggestions on what to try next VERY much appreciated
69 chevy SWB 70 GTO 65 GTO hardtop 65 GTO ragtop 77 Trans Am Hmmm. Too many pontiacs, not enough chevy trucks yet. |
10-09-2003, 02:55 PM | #2 |
faster, faster, faster
remember to turn it off untill you can fix it.lol
I'm going to Law School, wanna debate? It's good practice. |
10-09-2003, 03:09 PM | #3 |
former desert rat
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Where at in Utah are you? If you are in the Salt Lake valley, I could take a look at it for ya. I beleive you said something about Provo though...If you havent figured it out by Friday, let me know.
John
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const. |
10-09-2003, 03:42 PM | #4 |
Black 72 Chevy
For eight years my problem was this part that was broken and turn signals would not cancel by them selft.
10-09-2003, 03:49 PM | #5 |
Black 72 Chevy
An other pic of where it was broken.
10-09-2003, 03:54 PM | #6 |
Black 72 Chevy
Last pic. to where this piece is located.
10-09-2003, 08:02 PM | #7 |
its all about the +6 inches
Is the shaft loose in the column?
10-10-2003, 10:43 AM | #8 |
By shaft, you mean the very center? I don't believe it's loose.......Its seems like whatever is supposed to put tension on those cancel springs isn't happening.......
10-10-2003, 12:14 PM | #9 |
I recently replaced the whole harness for the same reason, problem solved.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
10-10-2003, 12:28 PM | #10 |
Some possibilities: Cancelling cam is worn, spring is missing on bottom end of shaft, (non tilt column), spring is missing between cancelling cam and steering wheel, (tilt column), and cancelling springs are installed on the wrong sides.
Good luck! Let us know what you find. Jim |
10-13-2003, 02:42 AM | #11 |
Black 72 Chevy
Its possible that you are missing the piece that the errow is point at?
10-19-2003, 04:24 AM | #12 |
Black 72 Chevy
backinblack
Did you fix the problem of the cancelling turn signal?
72 Chevy, SWB, 350engine, TH400 |
