Old 10-23-2016, 10:24 PM   #1
reed62
reed62's Avatar
Bench Seat Tilt?
Hey all,
My seat seems to be upholstered in such a way that the back does not tilt forward. I am assuming it was able to tilt forward from the factory in order to access the fuel tank. Correct?
reed62 is offline   Reply With Quote
Old 10-23-2016, 10:29 PM   #2
DPowers
DPowers's Avatar
Re: Bench Seat Tilt?
Correct- it should look something like this.
DPowers is offline   Reply With Quote
Old 10-23-2016, 10:32 PM   #3
reed62
reed62's Avatar
Yep. Mine has the same black curvy arm but the upholstery comes almost 3/4 the way down that arm causing it not tilt.
Old 10-23-2016, 10:41 PM   #4
DPowers
DPowers's Avatar
Can you loosen the upholstery and then reattach so it allows movement?
Old 10-23-2016, 10:48 PM   #5
reed62
reed62's Avatar
It's an old seat cover and will be replaced in the next few months. Just wanted to make sure it had that functionality.
Thanks for the responses.
Old 10-24-2016, 12:45 PM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Early bench seats had this function. Later ones did not. Are you sure this is the original seat? I think '69 was the change over year IIRC.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
