Old 10-23-2016, 10:59 PM   #1
Kaptain Kadian
Kaptain Kadian's Avatar
Air out of vents is still hot
I have disconnected the ac from my truck and have replaced the heater cut off valve and the air that is coming out of my vents is still hot. I don't expect it to be cook, but it still feels like heater hot. How hot is the air supposed to be coming out of the vents when you don't have the ac hooked up, but the heater controls are set to ac?
Kaptain Kadian is offline   Reply With Quote
Old 10-23-2016, 11:42 PM   #2
barry1982
Re: Air out of vents is still hot
I had a similar problem a few years back. Turns out a fairly large nail fell down one of the defroster vents, and got stuck in the heater box. This prevented one of the little doors from closing completely, and allowed cold are to mix with hot from the heater core.
barry1982 is offline   Reply With Quote
Old 10-24-2016, 12:25 AM   #3
Kaptain Kadian
Thanks for the reply, but I recently replaced the diverted box under the dash and cleaned out all debris. That all should be working now. I replaced all the vacuum lines and made sure they are all plumbed correctly as well.
Old 10-24-2016, 07:31 AM   #4
67 chevelle
67 chevelle's Avatar
try bypassing your heater hoses to see if that is it , if it is maybe the diverter valve is defective
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 10-27-2016, 06:02 PM   #5
Kaptain Kadian
How can I test the vacuum system to see if it is working?
Old 10-27-2016, 07:23 PM   #6
firedemon
on some of the valves if theyre hooked up backwards the pressure will open the valve
firedemon is offline   Reply With Quote
Old 10-27-2016, 11:10 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Air out of vents is still hot
Going by what you said it sounds like the difram is either the wrong one are it's bad. These trucks had 2 kinds of vacuum valves. Vacuum applied to one valve opened it. Vacuum applied to the other closed it.
The 2 valves look the same and the only way to know for sure is to apply vacuum and see if it opens are shuts.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
