![]() Join Date: Jul 2016
Attached is pictures of my 1967 Chevy C20 power steering power cylinder attach point & a reference picture. I did not notice the weld job until I cleaned for paint. (Picture has rust converter primer on it.)
My question is: do you think its safe? Not telling where to find another, unless you (someone out there) has one to sell and ship to me? R/ DJ |
Re: C20 PWR Steering Attach Point
If the part were to fail it could possibly lock up the steering, but it might just break free & you would have no power assist. Personally, I would replace it or replicate the part (if one can't be found). The part looks cast but could be fabricated out of mild steel with a little work. With that said, no telling how long it's been welded & it's still holding! I would replace for "peace of mind".
Bracket is simply bolted in place behind steering box.
Need to find replacement from salvage truck - key is finding 67 to 72 WITH Factory power steering. R/ DJ |
It's a 67 only part!
68 and up used the power steering gear box.No slave cylinder. 66 and under used the same bracket,but it is slightly smaller and won't fit the 67 frame. I have the complete 67 set-up I bought for my 64,C-10.This bracket is the only part that won't work on it! Mike. ![]() |
#5 | |
Old member
![]() Quote:
The 64 SS Impala had it and I just took it all off. My part like this was bolted on and was part of the front sway bar mount so I left it installed for now til I find another mount. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thank you Andy4639 for the feedback. I just don't know the true quality of weld and last time a front end broke on me, (tie rod assembly failed - broke), I only remember ending up in intensive care at hospital. That was years ago, but do not care to have anything remotely happen like that again. I am working a lead now on a salvaged replacement part, wish me luck.
R/ DJ |
Old member
As stated before these where used on early models. I hate them. I took the one off my 67 the same day I bought it years ago. Even at their best they lack in power to what a real power steering box has in my opinion. I'm not a purist either though so modifying one isn't a problem for me.
I can understand if you are going for show points though. ![]()
Not a "Purist" here either. But post divorce budget (& her debt pay-off, etc.) makes this rebuild just do what is needed to get it road worthy and safe.
Also, I found a replacement salvaged bracket in great shape for $30 (plus shipping). I'm happy with that. |
#9 | |
Old member
![]() Quote:
#10 | |
For those in the dark here, 67 and some 68 trucks ran an external assist cylinder like a 'vette.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
The Older Generation
My '68 CST/Custom Camper has power assist power steering and it works very well. LockDoc
Removed and cleaned-up original "repaired" bracket today and it was only BRAZED!!!
Have salvaged one on way (second picture) ;-) ![]() DJ |
