Old 10-24-2016, 11:06 AM   #1
warriorsimi
Any independent rear suspension c10's ?
I just stumbled on a kit for rear independent suspension on an old Ford truck and thought it was really neat.has anybody done this on a c10? It looks like maybe a thunderbird rear end would work but since I am not home to take measurements I don't know for sure.i do know that I saw a video from I think it was the guy from roadkill that did one.pro's or cons ?
warriorsimi is offline   Reply With Quote
Old 10-24-2016, 12:00 PM   #2
wbc409
Re: Any independent rear suspension c10's ?
You are talking about Finnegan. If I remember correctly the IRS he used came out of a navigator. He said it works better because of the design and layout of the control arms.
wbc409 is offline   Reply With Quote
Old 10-24-2016, 12:05 PM   #3
warriorsimi
Yes sir that is the video thank you.
Old 10-24-2016, 04:15 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Finnegans is on a "67 c10" there really isn't anything c10 about it. And most of the rear end is custom. There is a kit to mount c4 irs to our trucks. I'm sure a jag rear would be pretty easy too.
They all have their benifits depending on what you use your truck for and what your expectations are.
I had a c4 irs that I picked up cheap at an auction. It looked like a pretty easy install depending on desired ride height. It was hard to sell it.
brad_man_72 is offline   Reply With Quote
Old 10-24-2016, 05:21 PM   #5
warriorsimi
I have been trying to figure out the best options for my truck ,I have leafs on it now with a notch and flip kit and bagged,but the ride is not as nice as I had hoped for so I was thinking of four linking it and that is when I saw the video.my truck is going to be basically just a cruiser not a hauler.i figured if I did a IRS system then I would have rear disk and maybe even limited slip.for about the same as a four link set up.i also want an ls swap.
Old 10-24-2016, 06:16 PM   #6
brad_man_72
the boat guy
Leafs and bagged... a bagged trailing arm setup may be your best bet for a cruiser. Hell even hardcore autocross guys aren't going independent.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
Old 06-08-2017, 12:37 PM   #7
leftybass209
leftybass209's Avatar
There is a company that has a bracket kit for 64-66 C10's to accommodate a C4 IRS.
http://www.progressiveautomotive.com...-irs-kits.html
1964-66 Chevy C10 truck bracket kit* LV-CTH $1,525
*Note, includes rear boxing plates and Ride Tech HQ coil-overs
leftybass209 is offline   Reply With Quote
Old 06-08-2017, 12:40 PM   #8
leftybass209
This one is extreme with it's mods...
http://67-72chevytrucks.com/vboard/s...306237&page=33
