Cutting holes in the bumper
Well, I took my front bumper off yesterday, and attempted to cut the holes for my driving lights, with a hole saw, as suggested.
Not gonna happen. Each time the teeth would grab, the drill press stopped. I think if I used the abrasive type edge it might work better, but I'm just going to take it to a welder shop and have him cut them out with a plasma cutter, or acetylene torch. |
Re: Cutting holes in the bumper
What are you using for cutting oil?
![]() Join Date: May 2012
White K20 |
It's done. I took it to my Welder neighbor, and he had them cut out in about 5 minutes.
I wish I would have done this first. (I would have saved $40) Now all I have to do is clean up the openings sand the whole bumper, and paint. I'll take pics, before and after, and then again when I get the lights installed. |
#5 | |
Old member
![]() Quote:
If not your lights will do very little for driving. The front bumper when mounted looks like this. Tilted down. \Truck ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Update with pics.
So I had the neighbor cut the holes with his acetylene torch (universal metal saw), bug ad him ct smaller than I needed. Today I used my angle grinder to finish out the holes, measuring, and remeasuring about 20 times, because we all know that once metal is ground away, it ain't coming back. Once I finished the holes, I took the Orbital Sander to the whole bumper to get rid of any chips, and scratches. Next I rough sanded the back, and sprayed it with Semi Gloss Black. That's where I'm at right now, so I'll finish the paint in the morning, and put the lights on late tomorrow afternoon. That's the plan any way. ![]() |
One of the sanding in progress
Last one for tonight
Sanding in progress on the front |
Here's how far got today.
It's painted, front plate installed and upper center brackets installed. I'm letting the paint cure over night so that I don't screw it up during install |
Neat! those are big holes! keep us posted with pics!!
Yeah, they're just a tad over 4 inches. The driving lights I'm putting in are from a Pontiac, I think, and they are 3 7/8 in diameter. I've got a border to line the openings, which will fill the space in between.
As near as I can tell, the LMC bumpers have about the same sized holes |
