![]() Join Date: Jun 2016
Inner Door Insulation
So, I'm thinking about putting the foil backed Butyl sheets inside of the doors and was wondering if there is an easier way to remove the factory "insulation" that looks like it was sprayed on. It covers almost all of the inside of the door going up and down past the lower side trim mounting holes. The door shell is pretty tight and I'm not seeing how to get in there to scrap or chisel it all off. Thanks!
The Older Generation
Re: Inner Door Insulation
I find it near impossible to get off so I just spray another coat over the top of it and live with it. I don't know how much insulation it provides but it actually does a good job of sound deadening. LockDoc
Junior Member
![]() Join Date: Mar 2015
Just curious, could you put the foil sheet over/on top of the insulation?
#4 | |
Not sure how good it would stick. Is it adhesive backed or do you use spray glue on it? LockDoc
I picked up a 36sqft box of Dynamat from a buddy who had it left over from his insulation job. So it's the Foil/Butyl peel and stick-on kind.
Problem I see with sticking it on the original is the possibility of the added weight (this stuff is heavy!)pulling parts of the original insulation away from the outer skin. But that's just a guess? |
#6 | |
What do you spray over the top of the original insulation? Thanks |
#7 | |
LockDoc
I had the same issue with the undercoating. What I did was used the dynamat on the back of the steel interior door panels.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I agree with others on dynomat being a good choice. It is heavy but provides a great barrier for sound/road noise.
I got in there with a 1.5" putty knife and scraped off all the old stuff. Came off pretty easy and it doesn't cover the entire door skin so it didn't take too long. I then used Fatmat on the skin and the inner panel on the inside.
Dynamat is NOT a good sound barrier, it ONLY dampens panel vibration. If you want sound deadening you need to use a sound barrier. It is hard in these vehicles since there isn't as much room to hide a second and third layer of material in the doors. I plan on putting as much as I can behind the door card and maybe hanging/gluing some to the inside of the door, but that won't be easy |
