Old 10-09-2003, 03:33 PM   #1
wildwood
wildwood's Avatar
drum to disk
Hey everybody. Could someone advise me on the parts required for converting the Dann 44 drum brakes on a '70 GMC K10 to disk? Would I be able to siply take the setup from a newer K10, or would it have to be from a 67-72 with disks? Thanks
You can't get out if ya don't get in
wildwood is offline   Reply With Quote
Old 10-09-2003, 09:16 PM   #2
Pont
I need another Barley Pop
Pont's Avatar
It's an easy swap. I took the drum Dana 44 out of my 67 and bolted in a later model (77 or 78 I think) Disc Dana 44. Everthing should just bolt up. Using later model brake hoses also threaded directly to the original fitting at the frame. Let us know if you run into any problems that I'm not aware of.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 10-09-2003, 09:37 PM   #3
mkmiller1
mkmiller1's Avatar
Can you change the gears(say 3.07 to 3.73) in a D44? I know that you can't do this in the carriers in 12B, just never heard about a Dana.
Thanks,
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 10-10-2003, 05:15 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
It appears that the cut off for changing carriers is 3.73 and down and 3.92 and up.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-21-2003, 11:24 PM   #5
Scrub
Collector of rusty Items
Scrub's Avatar
I think you will need a disc type master cylinder and a disc proportioning valve to work correctly. I did on mine. Disc brakes use more fluid than drums.
dejavue
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 10-22-2003, 06:59 PM   #6
wildwood
wildwood's Avatar
I've got the proportioning valve and booster from a disk truck, but what I really need to know is if I can keep everything intact and just change the spindles and stuff from another D44 and if so which D44 or would I have to chang the whole thing out like pont mentioned.
As for the gear thing, you can get 4.10 gears to fit the 3.73 carrier from Motive. This comes in handy if you want to run bigger tires and keep that carrier
Thanks for the help guys
Old 10-22-2003, 08:11 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I was looking in a reider racing catalog. They have the same thing you mention for dana 60 axles. I did not see anything like that for 44s not that that means anything.
