Old 10-25-2016, 01:22 PM   #1
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Bed Assembly question - rear tack welds
When you guys are reassembling beds do you tack weld the rear crossmember back in like from the factory?
I took mine apart and had all the bodywork done when it got flooded. I sandblasted it and started over. It is in epoxy primer right now and I am finishing body work again. I was going to assemble the bed prior to paint but was wondering how others handled those tack welds.
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 10-25-2016, 01:27 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Bed Assembly question - rear tack welds
I would tack weld them like the factory. That way you will not get any movement of the bedsides that could cause your tailgate not to close correctly.
Hart_Rod is offline   Reply With Quote
Old 10-25-2016, 02:55 PM   #3
Bagd72Chevy
C10 Collector
Thats what I was thinking. Now I need to come up with a way to transport an assembled bed with no floor.
Maybe I will make a bed cart and bolt temporary crossmembers up or something to attach to the inner bedsides.
///Ryan
1971 Blazer - Rusty
Old 10-25-2016, 03:04 PM   #4
Hart_Rod
Hart_Rod's Avatar
Why not just borrow a welder?
Old 10-25-2016, 03:05 PM   #5
Bagd72Chevy
C10 Collector
I have plenty of welders but the paint shop is an hour away. Got to weld it before paint but put floor in after paint
///Ryan
1971 Blazer - Rusty
Old 10-29-2016, 07:02 AM   #6
cleanfreak
cleanfreak's Avatar
Been thinking of the same thing also. how about drilling a couple more holes to fit tightly on a 5/16 bolt after alignment has been done?
cleanfreak is offline   Reply With Quote
Old 10-29-2016, 08:51 AM   #7
Katrina/10
Katrina/10's Avatar
I never welded mine after taking it apart and putting it back together, and it has never moved. Just made sure all six bolts on each side are really tight. If you plan to haul heavy loads against the bed sides, a weld might be needed.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
