1989 R3500 frame same as C30?
From my reading I think the 89 r3500 shares the same frame and front suspension as the C30.
Can anyone confirm or deny this? Thanks in advance |
Re: 1989 R3500 frame same as C30?
Crew cabs in 89 (88-91) are the same.
That would be asking if an r3500 is the same as an r3500.
I'm asking if it's the same as a c30 ie an 85 for sake of argument |
I would think so...
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
#5 | |
We just changed the code to prevent confusion with the new GMT400. When I need parts for my '87 R10 truck I normally tell the parts guy it's an '86 C10. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Yeah gm kept the square body around tell 91,88-91 the crew cab the k5 blazer and suburban was still the square body.They had to rename the 1 ton crew cab because they had the gmt400 body out in 88 but it was standard cab and extended cab.The gmt400 didn't get a crew cab tell after 92.But its not just gm doing that ford has done it also.But ford did it with the f250/f350 keeping the old body a few years after the f150 has a new body.
#7 | |||
88-91 r3500's are the same as pre-88 C30's when comparing suspensions & frames. Interior & body parts are the same. Wiring & electronics are different.
![]() Join Date: Jun 2016
To extend upon this further, are the 10,20 and 30 series frames the same? Thus is a C10 frame the same as the R30 frame? Specifically from a front suspension and steering perspective.
No. Completely different from c10 to c30
#10 | |
88-98 c1500-3500's are very different.
Yes. The front x-member, trans x-member, & 2 rear x-members are all similar. The trans x-member is taller on a r3500/C30 vs a C10 (frame channel is 2" taller under the body).
#13 |
Thanks. The reason I am asking is because I am looking at one of the rack & pinion steering kits. The only list it for the C10. I made a couple inquiries and asked if they could send measurements on their cradle and all they will tell me is "it won't fit". I need all new steering so this would be the perfect time for that swap.
#14 | |
I would however research what the R&P's 'original' intended vehicle was to know the weight it was designed for. A dually front end is some heavy stuff vs a C10. I used an aftermarket C10 trans x-member on mine. All I did was increase the height where it bolts into the frame channel. And I added another rear C10 x-member right behind the rear-end on mine.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-27-2016 at 08:25 PM. |
#15 |
Next!
fyi
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
