Old 10-25-2016, 03:42 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
May Have Found Deluxe Seat Foam :)
I was looking at the seat foam I have for my truck. It came from a Custom Cab so the seat foam is full foam.
The number on it says 3187055.
I search GM Parts Wiki and found in the 1969 page (among others) 3817055 fits 1969 bench seats. Am I reading that wrong?
http://www.gmpartswiki.com/getpage?pageid=219986
Cause if it's right . . .
And in the 1976 parts catalog it says it fits 65-68:
http://www.gmpartswiki.com/getpage?pageid=62700
Old 10-25-2016, 11:49 PM   #2
Rogue 64
Ol' Blue Viking
Re: May Have Found Custom Seat Foam :)
Wow, thats cool
Driving Paw-paws truck into the Sunset!
Rogue 64 is offline   Reply With Quote
Old 10-26-2016, 08:24 AM   #3
60-66
60-66's Avatar
When reading the parts book you have to included the sentence above also where it says 62-68 Cab W full Foam Seat
69 Cab .....3187055
The full Foam seat was also available for standard seats.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 10-27-2016, 10:28 AM   #4
The Rocknrod
Moderator
That's exactly right full foam.
Old 10-27-2016, 10:32 AM   #5
The Rocknrod
Moderator
This seat frame.
Old 10-27-2016, 01:05 PM   #6
jhrusk
Does the foam from later models work on 64-66 seats. If so standard or deluxe?
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 10-27-2016, 03:14 PM   #7
The Rocknrod
Moderator
That's what the question in post #1 is about.
The Deluxe seat is the Full Foam seat shown in #5 above. The standard seat has straight springs front to back of the seat frame.
Old 10-28-2016, 10:28 AM   #8
The Rocknrod
Moderator
So the foam would be this?: https://www.tuckersparts.com/67-68-C...ion-only..html
Looks like the foam bottom I have:
Old 10-28-2016, 01:09 PM   #9
61K10
61K10's Avatar
Just a note--not for 60-61. 62up as you have posted. my seat base is different and my tk has the custom comfort op. It had the cloth cover also (found a few pieces) my seat base is flat.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-29-2016, 03:40 PM   #10
The Rocknrod
Moderator
Man I thought I'd get a bunch of kudo's (Bravo Zulu's) on this one. I guess everyone already knew? Expect me. I'll go back to sleep.
Old 10-29-2016, 04:54 PM   #11
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
KUDO's to ya Bud,
didn't know that fact. It takes someone to ask the question in order for the research to be done.
Old 10-29-2016, 11:57 PM   #12
Rogue
Airport Bum
I was excited to see this, Master Chief!
Nothing worse than a nice truck with a crappy uncomfortable seat.
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 10-30-2016, 12:38 PM   #13
61K10
61K10's Avatar
I don't think most knew about this. Not much info about seat springs and foam, just what fabric pattern and color. So thanks for posting.
1961 chevy K10
Old 10-30-2016, 12:56 PM   #14
MusicMan70
MusicMan70's Avatar
Kudos for this great info find Rocknrod!
I know this will help many others, Thanks.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 10-30-2016, 01:55 PM   #15
Gunnin4ya
Thank You, Thank You. You just saved me a ton of time. Was just starting to look for foam with ZERO results.
Gunnin4ya is offline   Reply With Quote
Old 10-30-2016, 04:24 PM   #16
The Rocknrod
Moderator
Ya there is no info anywhere I can find on the full foam seats either and the aftermarket sellers cannot address the issue. I was just lucky finding that number I guess.
Old 10-31-2016, 12:47 PM   #17
61K10
61K10's Avatar
So lets go one step further. Is there two types of seat base springs? 62-up? the one you show is not flat but recessed for the thick foam.
1961 chevy K10
Old 10-31-2016, 04:21 PM   #18
The Rocknrod
Moderator
Here is a great post that shows the difference in the two types of seat springs:
http://67-72chevytrucks.com/vboard/s...78&postcount=2
The better post: http://67-72chevytrucks.com/vboard/s...23&postcount=7
Old 10-11-2017, 12:37 AM   #19
La Zona Imagery
So if I currently have the standard seats, I can use this full foam replacement on my seat frame?
1965 Chevy C-10 350 V8
2003 GMC Sierra Crew Cab 6.0L 4x4
La Zona Imagery is offline   Reply With Quote
Old 10-11-2017, 08:41 AM   #20
The Rocknrod
Moderator
No.
Old 10-11-2017, 09:25 AM   #21
aotte1
What do you think of it's quality? Made in USA?
Good to know same as later year trucks.
Thanks,
Les
aotte1 is offline   Reply With Quote
Old 10-11-2017, 09:40 AM   #22
The Rocknrod
Moderator
Some info on standard seat foam. http://67-72chevytrucks.com/vboard/s...d.php?t=640827
We should start a thread on Standard Seats maybe?
Old 10-11-2017, 10:36 AM   #23
oldtrux
oldtrux's Avatar
great info rocknrod,so this should fit my 66 with deluxe seat?an extra 10% off at
tuckers right now too!pulled my seat apart and foam has number 3816940
thanks for the info!
oldtrux is offline   Reply With Quote
Old 10-11-2017, 11:35 AM   #24
The Rocknrod
Moderator
That's my opinion. Haven't heard anyone say otherwise. Can't seem to find your part number in the GM parts Wiki. Make sure your lower seat springs look like post #5, not straight from front to rear. Ya the lower foam is only $130'somethin bucks right now. If I had a job I'd buy it.
Old 10-11-2017, 11:47 AM   #25
oldtrux
oldtrux's Avatar
yes mine is like post # 5,just to further complicate things i wonder if the next tuckers #d1054 would also give us the foam for the back needed?hhhmmm
actually i think d1054 is a full foam back
lmc has it with full foam back or thinner foam back like our deluxe seats....but more expensive
