68 C10 LS Build
OK Guys, I am in the process of my first LS swap. Figured I would jump on the forum wagon and keep you all updated with my progress. This project started out as a dual quad 327, TH350 and is being swapped for a freshly built 2001 Camaro ls1/4l60e. Here are some pics of the progress so far.
Re: 68 C10 LS Build
You have my attention...
Re: 68 C10 LS Build
I'm planning on a 5.3 swap in my 68.
What did you use for motor mounts? |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 68 C10 LS Build
Nice and welcome!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: 68 C10 LS Build
I'm always curious to see other guys ideas on their installs.
checkout "Blakes 67 build" I installed a 5.3 in his Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
Re: 68 C10 LS Build
I used the ones from lsxinnovations.com. I had to move my motor perches back 1" in order for the pan to clear the crossmember. If I ever do it again, I would just go ahead and purchase the dirty dingo sliders. But, mine were only 25 buck on ebay so Im not complaining.
Re: 68 C10 LS Build
Following this thread as I'll be doing the same install in my '65. Good luck!
Re: 68 C10 LS Build
You can also use the relocation plates from ICT Billet around 35.00 from summit. bolt them to the block and drop it back in with stock small block mounts .
Mark...
Re: 68 C10 LS Build
#10 | |
Re: 68 C10 LS Build
Re: 68 C10 LS Build
Thank's lowhd01!
It was a basket case when it rolled in the shop and A TON of work but it came out super nice and the Customer loves it! Mark...
