Old 10-26-2016, 02:28 PM   #1
mrcomedy104
First time swapping a motor, don't have much experience
Would anyone be able to help? I know this might be easy to most of you here, I'm not very savvy when it comes to mechanics, I can do the usual maintenance on any vehicle, but this is the first time I swap a motor, so my question is, how do I align the motor to the transmission, it's in but it won't close all the way, I'm doing this on my own, moving the engine hoist and the jack from the transmission to align it but it's not going in, the motor is a 305 off a 85 camaro, and the transmission is a th350 off the truck 72 c20, would that be the issue?
mrcomedy104 is offline   Reply With Quote
Old 10-26-2016, 03:17 PM   #2
Wrenchbender Ret
Re: First time swapping a motor, don't have much experience
You probably don't have the converter all the way back in the trans. There are about 3 steps going in. You have to rotate the converter holding the weight up till it drops back. The engine should bolt right up to that trans. If you get the angles the same & the dowels go into the holes it will fit up. The converter will be about 1/4 in back from the flywheel. After you get the engine bolted to the trans. You can drop it down on the mounts. Pull the converter forward to the flywheel & bolt it up.
Wrenchbender Ret is offline   Reply With Quote
Old 10-26-2016, 04:45 PM   #3
mrcomedy104
I'm trying to upload an image of how far it's in there it's pretty much there but won't go in anymore than that
Old 10-26-2016, 04:51 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Dowel pin in the transmission isn't lined up with the engine. The tranny and engine MUST mate up flush with each other.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-26-2016, 04:52 PM   #5
GR8-68
GR8-68's Avatar
It appears you are probably close as you might get, put your bolts in the bell housing and it should draw together, just don't force it. If it feels real hard to run the bolts in stop. Also like Wrenchbender said look up from the bottom and make sure your torque converter isn't bottomed out on the flywheel
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 10-26-2016, 05:01 PM   #6
mrcomedy104
Old 10-26-2016, 05:04 PM   #7
mrcomedy104
Gary
Do I have to rotate the flywheel? The pins that go from the motor to the hole on the transmission are aligned, and in but nit all the way
Old 10-26-2016, 05:18 PM   #8
randy500
Turn the torque converter by hand and while turning push it in. It should not be touching the flywheel at all even when the transmission is fully bolted to the engine
randy500 is offline   Reply With Quote
Old 10-26-2016, 05:19 PM   #9
randy500
You have it close so put a few bolts in to keep the alignment and check the converter clearance.
Old 10-26-2016, 06:03 PM   #10
mrcomedy104
That's all it needed, as soon as I put two in, it closed all the way, thank you all for all of your help
Old 10-27-2016, 12:05 PM   #11
GASoline71
GASoline71's Avatar
Great!
I realized this morning I said the dowels in the transmission, but I meant the dowels in the engine to line up the transmission.
Good job!
Gary
