Old 10-26-2016, 03:59 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Inline Power Steering Bracket Diagram
I'm installing a 250 in my truck and also adding power steering to it. Does anyone have a diagram of the power steering setup on an inline motor. This is what I got but can't figure out how it bolts on.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 10-26-2016, 04:40 PM   #2
cjrolke
Re: Inline Power Steering Bracket Diagram
interested as well I have a 250 with power steering and would like to get that part up and working
cjrolke is offline   Reply With Quote
Old 10-26-2016, 05:15 PM   #3
SS Tim
SS Tim's Avatar
Pictures that should help some.
http://67-72chevytrucks.com/vboard/s...82&postcount=1
SS Tim is offline   Reply With Quote
Old 10-27-2016, 10:22 AM   #4
Gmc.guy
Gmc.guy's Avatar
This is the bracket shown without a pump. You should have to remove the top alternator bracket you have on your engine now and replace it with the one you got with the new pump
-Cody
Gmc.guy is offline   Reply With Quote
Old 10-27-2016, 10:33 AM   #5
5150
C10 Club Tennessee
5150's Avatar
Thanks Cody!
Bryan
www.gmtruckshow.com
Old 10-27-2016, 01:30 PM   #6
RichardJ
Notice in the link from SSTim, the two damper pulley grooves line up with the water pump pulley grooves like yours.
The GMCguy picture has a damper with wide space between grooves and the outside damper groove lines up with the inside pump groove.
A lot of variables to contend with, but I think all use a double Alt pulley.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 10-27-2016, 04:34 PM   #7
5150
C10 Club Tennessee
5150's Avatar
Well, not quite a fit.
Bryan
www.gmtruckshow.com
Old 10-27-2016, 06:34 PM   #8
old51sedan
old51sedan's Avatar
I just installed PS on my 250. It's hard to see your smaller bracket, but it should bolt on top of the head between the two front head bolts where there is a hole with no bolt and also bolt to one of the bolts on the top side of the water pump. It will sit over the top of the exhaust manifold and right in front of the intake.
old51sedan is offline   Reply With Quote
Old 10-27-2016, 06:46 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Are you sure those are the correct brackets for a non-integrated head? They might be from a later model six cylinder.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 10-27-2016, 07:37 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Flipped GMC.guy's picture. A lot of difference between that bracket and yours....
LockDoc
Leon
Old 10-27-2016, 10:23 PM   #11
70STOVEBOLT
70STOVEBOLT's Avatar
Those brackets are for an integrated head 250 I believe.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 10-27-2016, 10:39 PM   #12
'68OrangeSunshine
'68OrangeSunshine's Avatar
Here's what I bought off a board member, about 20 years ago. He thought they were for a 292 -- since they looked "different" -- but they are for a 250 anyway.
Wonder if I could Make them fit. This particular exhaust is the heavy duty manifold with 3 studs not 2 and cooling fins. Fins interfere with bracket. Might fit w/headers, ya know?
Too late for a refund now.
Old 10-28-2016, 12:14 AM   #13
Gmc.guy
Gmc.guy's Avatar
I have a complete integrated 250 I'll take a pic tomorrow. Maybe we can compare. I know the upper bracket worked when I pieced it together years ago
-Cody
Old 10-28-2016, 08:20 AM   #14
70STOVEBOLT
These are what mine look like on my '70 with a 250.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
