![]() Join Date: May 2012
Seats
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
Re: Seats
That's trick, they look great, and match the interior theme, great job!
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Seats
Those seats look great
Re: Seats
Nice
Re: Seats
Nice interior! Does the column shift indicator move with the floor shifter?
Re: Seats
Can we see the rest of the truck ,inside looks killer ?
Re: Seats
No the shift indicator does not move, motor is a 540 ci. Did all the work my self, paint ,body, motor build. Fun two year frame off.!! Thanks for the comments.!!
![]() ![]() Before I put the tail gate on it ,but see the tubs and bed. ![]() ![]() ![]() Nice pin stripping helps break up the two colors.!! ![]()
Re: Seats
Damn ,that is sharp.
Re: Seats
I like the way you hid the A/C compressor!
Re: Seats
Re: Seats
That radio is indeed sneaky. Sneaky is good! Nice rig there. Should scoot pretty well.
The interior is real slick as well. Nice work! Did you do anything for sound proofing and if so, how well does it work?
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
Re: Seats
I used a lot of the lowes duct insulation. It is just like dana mat , just a little cheaper and easier to get.!! Seems to work really well.!! It comes in a roll, alum. backing on one side and sticky back on the other side, about 1/4" thick.
#13 |
![]() Join Date: Oct 2009
Re: Seats
wow, you've got a lot of work in that truck, looks real nice. Glad you didn't forget cupholders! Very important accessory. The plastic ones I hang on the window sill usually end up spilling stuff all over my left leg...
#14 |
Re: Seats
They make some cup holders that go in Lazy boy chairs. They have the coolest led lights , and a built in chiller, that will frost the holder up in about two minutes.!!!!!! all 12 volts.!!! My son and I put a set of them in his custom truck console.
