shock relocaters or shorter shocks
Which would be best on a 5 inch coil lowering on rear of 69 GMC ?
thanks |
Re: shock relocaters or shorter shocks
I made my own set of relocaters, someone here made a post showing how to use the existing brackets. I followed their instructions and it worked great .
Relocation would be best, you want that shock travel.
Om a 5" lowering I would do both ,shock angle will be way off ,travel of shock will be way off.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Florida Edition
![]() ![]() Join Date: Oct 2010
I used a relocator kit and stock shocks on mine, works fine.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
cpp - comes with hardware.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
My '71 GMC has 4" springs, 1" lowering block, shock relocators, shocks, & adj. panhard.... all CPP. I think it feels bouncy in the rear at Interstate speed. Particularly on concrete overpasses with expansion joints. Usually has no weight in the bed.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
Is it hitting the bump stops or C-notched? My 3" springs and 1" block feel awesome. I have the same stuff you do from CPP and the front 3" springs and lowered sway bar mounts.
It's not notched and it's not on the bump stops. It feels soft sprung with not enough shock damping. I have to confess I installed the shocks upside down when I first put it together. Might've damaged them internally maybe.
