66 suburban, LS install and suspension drop.
I have a 66 suburban in the shop right now. swapping the front suspension out to disc brake/5lug, and we plan on doing drop spindles front and rear springs to it, and installing an 02ish 5.3/4l60 in it. Anyone done an ls swap in this body and have any pointers? we have a complete late model suburban for the donor that runs and drives.
I'm not new to this, but haven't done the LS part yet, so not sure what else besides motor mount brackets, and rear trans crossmember that might be needed.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
Never Ending Projects
Re: 66 suburban, LS install and suspension drop.
I would recommend you check the LS Engine swap area on this forum.
http://67-72chevytrucks.com/vboard/f...play.php?f=206
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
60-66 Nut
![]() ![]() Join Date: Mar 2007
An LS swap into a '63-'66 body has been done many, many times. There are a few in the '60-'66 build threads section as well as in the LS swap section that Mike directed you to. The '63-'66 are basically the same as the '67-'72's also.
![]() Join Date: Aug 2014
The LS swap area on this forum has most all the info you'll ever need! Lots of great info there and VERY knowledgable guys in there! I couldnt of done my LS swap without them guys!
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
