MY TRUCK IS FOR SALE!!
Today in Houston, TX its been raining all day.....
I took my truck out and I cant seem to see through the window, ya wanna know why? MY DAMN defroster doesnt work!!!!! My heater works and my vent works..... There is air coming through the all the vents, except the defroster vents on top of the dash.... Does anyone know what might be the problem or a way to fix it so that air will come through the defroster vents???? Any input will be appreciative!!! Thanks!!
1979 Chevy LWB 350ci / 700R4 Edelbrock under the hood F O R S A L E OR T R A D E ![]() |
defroster
You need either to replace the switching cable that goes from the controls, to the air distribution box, or the flap on the box might be broke, and you will have to replace the air distribution box.
Tommy
junkyardpartseeker@sbcglobal.net |
So,
uh, how could I troubleshoot to find out what I need to replace or fix??? you know what I mean?
troubleshoot
Here we go. Lay down on your floorboard on your right side. Look at the air box, it's long and from the pass side to a bit past your trans hump going toward the driver side. Use left hand and switch your controls from defrost thru all the positions. If you don't hear or see it switching down on the top of the box, your cable could be broke.
If not the cable, than the flap could have broke, or even frozen in place and that means going to the salvage and getting another one.
C R A P ! ! ! ! ! ! ! ! ! !
crap!!!!!
If it is your cable, that means pulling your instrument bezel to get the heater controls out. And hooking up another cable and sending it down thru the dash to clip it on top. Now, there is a plastic clip on top of the air distribution box that holds the cable on it to switch, that might just be broke.
If it is the flaps, the whole air distribution box will need to come out. And it has the heater core inside of it. So consult a repair manual on how to remove the box.
Your killing me!!!!
No more posts from you, you are making me feel bad!!!! Just kidding!!! ![]() Thank you so much for the quick reply!! I am going to pull my truck into the garage and check it out in a little bit... For real Tommy, Thanks
Good luck
Ok, if you got aol messenger, I am jypartseeker there. I have my repair manual in front of me and can help you thru it.
I found out a lot of this by replacing the heater core in my new burb I am getting ready to switch to. It was a pita to get it out, and then figure where all the screws were to get the core out. Tommy
do you have any other Instant messengers?
yahoo? msn?
Oh,you can't buy that new
![]() Join Date: Apr 2000
79, everything that tommy said was right and if you feel it moving back there then your cable is OK it just may have moved in the bracket and does not open the inside flapper far enough. Before I pulled it apart you can physically try to move the metal arm farther in the same direction to see if it starts working then. DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
The full convertible guy
![]() Join Date: Jul 2001
Heres a quick fix as long as it is not raining too hard when you do it.
![]() ![]() Brad
2012 Kawasaki Vaquero (Lime Green) 2000 BMW 740iL 1995 Chevy ECSB riding on air 1975 GMC Jimmy 2WD lowered 4/6 1972 Chevy Trazer soon to be roadster 1965 Mustang 289/3 speed (friends dad bought it new) 1964 Chevy C10 (dad bought it new) |
tried that and found a problem.....
traffic sux, cause where there is rain there is traffic where there is traffic there is no air movement!! thanks for the input though.... seriously....
#13 |
crossy!!!!!
Do you know what that valve thing is for on the drivers side of the air box that sits on the tranny hump?
It has a wire or hose connected to it.... Also whats the deal with the metal flap thing on the very bottom, I pulled it open with my fingers but still no air goes up to the top of the dash (out the defroster vents).... Thanks bro!!
#14 |
well you live in TX. so I am assuming you have A/C . neither one of my current projects have A/C and i can't remember what one operates each control.
Also if you do have A/C then your controller switch is vacuum operated not mechanical like NON a/c trucks. if it has the vacuum switch then it is fairly common for that to go bad . check the main vacuum sorce to be sure you are getting vacuum there. DAVE.
#15 | |
Re: crossy!!!!!
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock ![]() LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
#16 |
Right turn Clyde
Its a little late now but you can take the glove compartment out and see the top of the heatcore box where all the cables are and the vacumm lines.
#17 |
cables
they are good....
I just dont know what to do anymore......
