Old 10-28-2016, 09:54 PM   #1
50procharged
1969 k1o Skyjacker lift HELP
I need help... Im putting a 2 inch skyjacker add a leaf in my sons truck ive already did the rear everything worked out great the front just dont look right I need your opinion on what to do.
[IMG][/IMG]
[IMG][/IMG]
50procharged is offline   Reply With Quote
Old 10-29-2016, 07:17 AM   #2
b454rat
Re: 1969 k1o Skyjacker lift HELP
I think you got the add a leaves backwards. That clamp is supposed to go on the rear, it keeps the leaves from fanning out....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 10-29-2016, 08:54 AM   #3
50procharged
There clamps on both ends of the add a leaf.
Old 10-29-2016, 09:49 AM   #4
50procharged
Should I remove those brackets and put some spring clamps on each end to pull the springs together?
Old 10-29-2016, 02:53 PM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
What does it look like with weight on it ?
BLAZERMAN is offline   Reply With Quote
Old 10-29-2016, 03:07 PM   #6
50procharged
It looks better but the bottom leaf hits the rivet head on the add a leaf spring and still a pretty good gap think I'm just gonna remove the rivet and just put some spring clamps on both ends.
Old 10-29-2016, 04:13 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Dumb question but nobody has mentioned this so I will. Shouldn't the AAL be installed under both existing springs instead of between them?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-29-2016, 04:26 PM   #8
69chevytrucker
69chevytrucker's Avatar
i just did a pro comp 2.5 lift on my truck it came with everything new shocks u-bolts front leaf springs and blocks for the rear and i paid $600.00 . so down in the states it would be like $350 - $400 at the most .
69chevytrucker is offline   Reply With Quote
Old 10-29-2016, 04:27 PM   #9
GSP7
GSP7's Avatar
Yup
But Id get rid of those add a leafs and get regular complete replacement springs
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 10-29-2016, 04:29 PM   #10
69chevytrucker
that's $600 Canadian i guess i should have said that since everything costs more in Canada
for Canadians
Old 10-29-2016, 04:33 PM   #11
GSP7
GSP7's Avatar
What happened to you truck ? Is that a blazer frame ?
Old 10-29-2016, 04:52 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Originally Posted by GSP7 View Post
Yup
No argument here, in fact that's exactly what I did many years ago with my K20.... 2 1/2" Softrides.
- Mike -
RIP El Jay
Old 10-29-2016, 06:03 PM   #13
69chevytrucker
yes it was a long box i put it on a 83 blazer frame and took about 30 inches out of the box at the front only
Old 10-29-2016, 06:48 PM   #14
50procharged
It said on the instruction sheet to put them in longest to shortest.
Old 10-30-2016, 06:49 PM   #15
First c10
First c10's Avatar
#54 of my hulk jr build I put rancho add a leafs front and back. They fit perfect for the 68 k10. It only has 2 leafs in the from and 2 in the rear. On the front I removed the lower leaf and replaced it with the add a leaf. In the rear I just added the heavy duty add a leaf.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 10-31-2016, 12:41 PM   #16
jeffahart
jeffahart's Avatar
That installation does not look correct. I think you got the wrong leaf. It's too long. Plus look at that gap between the leafs.
There's two ways to get the arch from the add a leaf method. From the bottom a smaller more curved add a leaf cups the upper leafs and when the center is clamped down it forces the center of the upper springs down into the cup. You get stiffer with some lift. Second method is add a spring to the top of the string pack, bolt it in the center and then force the bottom spring ends up to the added leaf ends to force the arch by pulling the ends up. Besides the gaps, it looks like you did not achieve any arch. You might have better luck with the HDs that bolt to the bottom. Over the years I've had a few over the top overload, but just for overload and not for lift. But same principle applies.
I think you got the wrong springs. They sometimes get products messed up for older applications. I got the wrong U bolts with my lift... pissed me off having the truck apart and not being able to finish because of their blundering.
White K20
jeffahart is offline   Reply With Quote
Old 10-31-2016, 02:04 PM   #17
50procharged
I just cut the brackets off and put them back in it looks alot better just need to get me a couple of spring clamps and just see what it does once I get everything bolted back up. Thanks for all the advice guys...
Old 10-31-2016, 02:12 PM   #18
jeffahart
jeffahart's Avatar
Ya, if you get the ends clapped good and lose that gap you will probably be fine and get your lift. Just get both sides clamped the same.
White K20
Old 11-26-2016, 11:46 PM   #19
50procharged
Just bout got it done just need new brakes on front. Here's a couple pics..
