Question for griffin radiator users
Just got in a griffin radiator for my 72. I need to know if the heavy duty radiator mounts will work with it. I don't wanna purchase mounts to find out they aren't compatable.
Re: Question for griffin radiator users
I used stock 3 core mounts. Either way the rad does not fit like OE. You will find the rubber cushions need a considerable amount of grinding to have the mounts sit tight to the rad support.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Does anyone have anymore clarity on this? I do not wanna start hacking away at my mounts.
My engine guy had a set of aluminum top mounts he modified to fit the Griffin radiator into my 71. Don't cinch it down as it will crack the radiator with any chassis flex, I found out the hard way. Mine cracked within the first thousand miles after being installed. Griffin repaired it under warranty. Now five thousand miles later I believe its cracked again. I won't buy another Griffin radiator.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
Well, I hope I have better luck with it.
Old member
I made a very simple cover for mine. I used black foam in the bottom of the support that is very thick. Then just cut the metal to fit the top and it works great.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Ordered heavy duty radiator mounts and they appear to fit perfectly.
Well, the HD mounts fit the width of the radiator, but they won't work as the radiator is too tall.
Update. Mine is cracked again. This radiator has less than 7 thousand miles on it. DO NOT BUY an aluminum radiator that uses epoxy! Griffin radiators are not welded, they use epoxy.
https://1drv.ms/v/s!AjxiC_Eliuofjg1aPQR58g-FzBew
#10 | |
