10-29-2016, 06:02 PM | #1 |
Tear down
I own a 1955 chevy 3100....I am looking for some help ( you tube videos etc) on how do ....
1). Remove the bed from the frame 2). Remove the inner and outer front fenders 3). Remove the engine and transmission 4). Re Wiring the entire truck If anyone know of any resources where I could get detailed instructions ....videos,books, your own experiences would be greatly appreciated Thank you |
10-29-2016, 10:09 PM | #2 |
Re: Tear down
Not to be a smartass but look for the bolts / nuts attaching each component, remove those, find some way to lift the thing off of / out of the frame. Done.
That said... Oldcarmanualproject.com has the original shop manuals for all of this and lots of our build threads have helpful pictures / how-to stuff. Removing the bed, crawl under the back of the truck with a 9/16 wrench in one hand and a flashlight in the other. Remove the 8 nuts holding the bed to the frame. Lift the bed off. Engine / trans... do you have an engine hoist? If not, you'll need to buy one.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
10-29-2016, 10:38 PM | #3 |
Re: Tear down
Get a copy of this reference book....it will give you a oversight and or encouragement to tackle the restoration...https://www.summitracing.com/parts/hpb-hp1534/overview/
I referred to it in the beginning of my 56 build 20+ years ago Joe |
10-30-2016, 12:36 AM | #5 |
Re: Tear down
I don't have any trouble removing that stuff. It's remembering how to put it back together that trips me up.
10-30-2016, 07:26 AM | #6 |
Re: Tear down
I had a simular problem when I bought my 54.Needed to start with the bed,my truck was an uncompleted project,could not get bolts out of the bed without removing the gas tank,could not remove gas tank till bed was removed.Ended up cutting heads off bed bolts,then welding nuts on frame for reassembly using 3/8"x 3 1/2" long stainless button head allen head bolts
10-30-2016, 08:44 AM | #7 |
Re: Tear down
before you start dissassembly take lots of pics so you can reference them later. when you take stuff apart do the same. put them on a memory stick and rename them as you go so they are not just a numbered pic. put them in named folders like "front fender", "hood and hinges", stuff that is easy to find later when you don't want to spend hours browsing. this will help alot when it comes to mock up or assembly time. an assembly manual would help as well,at that point. it shows how the little stuff fits right down to fasteners and clamps.
good luck,have fun, post pics. |
10-30-2016, 11:45 AM | #8 | |
Re: Tear down
Good luck. |
10-30-2016, 11:59 AM | #9 |
Re: Tear down
realistically these trucks can be disassembled with the most basic tools
90% of the bolts are 1/2'' and 9/16 with a smattering of other sizes i just throw all the bolts together, if getting it back together is an issue look at the factory assembly manual the fam is available at most vendors
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-30-2016, 12:29 PM | #10 |
Re: Tear down
Yes, take lots of pics, and get some Gallon, quart,sandwich size ziplock bags ,zip ties and tags a sharpie and a paint marker, label the bags and insert a paper tag inside the bag as well. larger items you can mark with the paint marker and a tag.
Number your bed supports,note spacing, take many pics of your e-brake springs brackets ect. Label the outside of your storage boxes as well, with what is in ea. bag . Wouldn't hurt to take pics of whats in ea box. a lot easier to look on the computer to see what you have and where it is than dig in the garage at 2am.. Most of the nuts and bolts will be trashed for new ones , I wouldn't worry about saving the clutch head screws ...(what that???) they were designed by the devil to get us all cussing and pissed off.replace with new hex head and be happy. |
10-30-2016, 01:11 PM | #11 |
Re: Tear down
what I have doe in the past, with some motorcycles and different things that have several different length bolts or some other oddity, is use some thin tie wire to hold the bolts in the holes they came out of. I assemble the multiple layers of things-loosely- with the bolts for that series of parts, even putting a spare nut from the bolt bin on the end sometimes if multiple layers look like they could easily fall apart in the box.then, when that box or bag or bin of parts comes out to be cleaned and get ready for assembly, you can easily see what went where. sometimes it can be years (right now my truck has been apart for 7 yrs) before you will look at those parts again. even if you plan on replacing the fasteners, you have a starting point.
10-30-2016, 01:56 PM | #12 |
Re: Tear down
As the others said they aren't that hard to take apart but sometimes you need to make sure you don't damage something when taking it apart.
From past experiences of having to figure out what size bolt goes there with what thread and how long does it have to be I'd save just about every bolt, screw and nut I took off just for reference, photographing, bagging and labeling them and tagging the photos in an album. You might want to start a Photobucket album just for the build that you can keep private if you want with separate albums on each section of the truck that you can add to as you go. That way you can have the photos organized with Tags on them to go back to and not have to scroll though hundreds of photos trying to find one.
10-30-2016, 06:55 PM | #13 |
Re: Tear down
Haven't posted this in a while.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
