Old 10-29-2016, 07:53 PM   #1
cagodinez
cagodinez's Avatar
P0175 p0172 p0650 long fuel trim -25.0
Just checking to see if any1 has had this same issue, this is my second time driving her and it feels like she is missing some power. It's a 2008 5.3 gen IV with e38 ecm. I have not checked for any vacuum leaks or exhaust leaks.
cagodinez is offline   Reply With Quote
Old 10-31-2016, 12:29 PM   #2
TooTall
Re: P0175 p0172 p0650 long fuel trim -25.0
injector is not fully closing or it's a dirty MAF. Has the engine been sitting for a while?
I'm willing to be that it's a dirty MAF. Try cleaning it first and then rescann again
If the code reappears again, run the engine with no MAF.
1984 K10, 8" lift on 35s
2011 Yukon XL | Bone stock
2013 Audi Q5
Old 10-31-2016, 01:52 PM   #3
cagodinez
cagodinez's Avatar
Thank you Tootall I will definitely try that, and yes the engine has been sitting 4 at least 2 years.
Old 10-31-2016, 01:54 PM   #4
TooTall
I would pull all of the injectors off, clean the fuel rail out, soak the injectors in SeaFoam, clean the screens and test
2013 Audi Q5
Old 10-31-2016, 02:35 PM   #5
cagodinez
cagodinez's Avatar
OK I will try that also.
Old 11-05-2016, 02:33 AM   #6
cagodinez
cagodinez's Avatar
I put in a new corvette fuel pressure regulater and the long fuel trim dropped down to -14, there is no change in fuel trim when I disconnect the MAF but, it runs a hell of alot better without it. So I'm still in the hunt for either a bad MAF, vacuum leak or stuck injectors.
