Old 10-29-2016, 10:19 PM   #1
Detroit Iron
Question No tail lights, the brake light and turn signals do work
I discovered on my 69 Chevy truck that the tail lights do not work. Would this be more of a fuse issue then both bulbs going out?
Detroit Iron is offline   Reply With Quote
Old 10-29-2016, 10:26 PM   #2
Clatterville trolley
Clatterville trolley's Avatar
Re: No tail lights, the brake light and turn signals do work
Have you checked for good grounds on the bed?? Do you have 12 volts in the light sockets - check with test light? Jay
Clatterville trolley is offline   Reply With Quote
Old 10-29-2016, 10:40 PM   #3
Detroit Iron
Thank You Jay, I did a quick check but I could not find a weak spot. I will have to wait for day light to dig deeper.
Old 10-30-2016, 07:54 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
trace the brown wire at tail lights forward. There's a connection on driver side just behind rear axle.
It could be a broken wire or bad headlight switch or many other possibilities
wire colors at back;
brown-tail
yellow-left turn
dark green-right turn
light green-back up
left and right turn are also respective brake light wires
has someone wired up for trailer lights? I see so many times they use scotch locks and they just invite corrosion into wire
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 11-02-2016, 08:55 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
On my truck it is the same fuse for stop and tail lights, so if the stop lights work, the fuse is good.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 11-03-2016, 04:12 PM   #6
tommy3horse
tommy3horse's Avatar
Mine had the exact issue, traced to the taillight wires that the PO spliced a trailer hookup to and did a super crappy job, using electrical tape and just twisted the wires together. The brown one was rubbing/shorting on the frame.
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline   Reply With Quote
