10-30-2016, 01:42 AM | #1 |
Blazer buckets into pickup
I've got a couple of sets of blazer low back buckets but cant seem to find any definite answers on how to go about fitting them in a bench seat pickup. My truck is a 76, anyone know of a link or does someone make brackets?
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com |
10-30-2016, 08:26 AM | #2 |
Re: Blazer buckets into pickup
The military M1010 ambulances had factory buckets, might be a good souce for the mounting brackets. http://www.73-87.com/7387garage/inte...ry_buckets.htm
10-30-2016, 09:20 AM | #3 |
Diggin The SquareLife
Suburban brackets
10-30-2016, 11:40 AM | #4 |
That link mentions suburban brackets are different. Will all suburban brackets work, even the late model ones that look nothing like these seats?
10-30-2016, 06:22 PM | #5 |
He is suggesting using the weld in inner Suburban brackets to mount them to the floor.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
10-30-2016, 06:48 PM | #6 |
OK, so the blazer seat rails will bolt to the suburban floor brackets welded to a pickup cab?
10-31-2016, 09:03 AM | #7 |
The only part of the Suburban/Blazer bracket that will work in a reg cab are the front mounts, the floors are different at the rear between the two.
I recently put Porsche buckets in my 77 and ordered seat mounts from WedgeBrackets.com. A bit pricey, but the fit was damn near perfect. The only hole I had to drill was the inner front, the inner rear bolts up to the seat belt mount, outside holes line up with the factory ones. I' sure with some fab work you could mate some sub brackets with some donor pieces from a bench to make it work, if you want to get in to all of that. |
10-31-2016, 10:30 AM | #8 |
Happy to be here
From what I know the Suburban brackets will work. The rear has to be bent to fit, and I believe a couple of holes drilled. Contact Capt Kaos for complete details on how its done.
11-01-2016, 10:36 AM | #9 |
I put Suburban buckets in my 86, just had to bend the rear ear of the tracks upward to match the floorpan in the pickup, and drill the inner rear hole. Mounted the floor bracket on the inner front and good to go.
11-01-2016, 10:38 AM | #10 |
www.73-87chevytrucks.com
You need suburban bucket seat brackets AND the inner front mount from the Suburban floor. None of the Blazer brackets work. Just unbolt them and bolt the Suburban brackets to the seat. The rear seat mounts have to be bent to match the floor angle of the truck.
There are also aftermarket brackets that work too. For more detailed info on bucket seats look here: http://forum.73-87chevytrucks.com/sm...?topic=28744.0
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 11-01-2016 at 11:05 AM. Reason: Added link to bucket article I wrote |
11-02-2016, 02:33 PM | #11 |
Found these brackets in a suburban with buckets with armrests today in the junkyard. They look different than all the other brackets I've seen pictures of, can anyone verify that they will work?
11-02-2016, 03:09 PM | #12 |
Yep, those are what you want. All the suburbans with buckets will have those.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
