Old 10-30-2016, 11:58 AM   #1
LongBox
Tail gate install tips?
My 69 came with the tailgate not installed, and now I'd like to put it on the truck. Questions: Is this a one-man job? It looks like I have to unbolt one hinge from the truck to do this job, is this correct? And, last question: Do I have to put the links that hold it open on before putting the tailgate into the hinges?
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 10-30-2016, 12:55 PM   #2
kcsa75
kcsa75's Avatar
Re: Tail gate install tips?
Never say never. But it's a heck of a lot easier if you have a helper. My son and I put the tailgate on my truck in about five minutes. We got lucky that it fit perfect the first time, didn't have to do any adjusting.
You can put the links on after it's bolted up.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 10-30-2016, 12:59 PM   #3
LongBox
Thanks. I can see how the trunnions bolt on, just wanted to be sure about needing extra hands, and about the links.
Rick
Old 10-30-2016, 01:43 PM   #4
John H.
John H.'s Avatar
It always helps to chase the bolt holes with a tap before so you can easily thread it together by hand. I do the same with the bolts.
John H. is offline   Reply With Quote
Old 10-30-2016, 05:50 PM   #5
LongBox
Good tip. I have lots of taps, not sure if I have the correct for this application, though. If i don't, I think I'll just remove the existing bolts, lube them, and run them in and out a couple of times to be sure they will thread in when we're holding the heavy tailgate...
Rick
Old 10-31-2016, 07:08 AM   #6
cdowns
cdowns's Avatar
I use an engine crane and cargo straps// easier to use and does as you say
Old 10-31-2016, 11:09 PM   #7
swamp rat
swamp rat's Avatar
FYI, there are aftermarket trunion's that are made of a poly material that are suppose to be quieter, have seen some post here on this forum, also someone makes one that is to turn the tailgate into a easy on and off by cutting a notch in the bottom of the gate and the trunion has 2 flat sides just like the 73-79 model. I assume some of the vendors on the vendor page would carry them, or possibly E-Bay
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-01-2016, 12:58 AM   #8
randy500
Great tip from John, do run a tap in the holes and make sure all the bolts will go in by hand. Do install one lower trunion and then tilt the gate in with the other on the gate. Leave off the link on the tilt in side as it can interfere with getting the gate to slip in. Its manageable for one person but can be a handful.
randy500 is offline   Reply With Quote
