85 body on a 74 frame
A friend of mine found a nice 85 c10 for sale that isnt running for a good deal and i want to get it...my 74 is getting quite rusty so my plan is to swap the 85 body on the 74 frame. My question is would this body swap bolt on straight up? My 74 also has a 5.3/4L60e swap so i figured it would easier to just swap bodies
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
Diggin The SquareLife
Re: 85 body on a 74 frame
Yes but u will need body bushings for the 85 cab an front end.....also will have to cut the front frame horns at a angle to get the 85 bumper to fit
Its a fairly direct swap, I just did one myself (86 body on 78 frame). You do NOT need to cut your frame horns, but the bumper brackets will need to be modified, which is easy.
Ok kool thanks
that's why ur brackets had to be modified cause you didn't cut ur front frame horns at an angle....if you cut ur frame horns you can use the 81-87 bumper brackets
Update... Picked up the new truck tonight(its actually an 83) and on the way home the 74 broke down...turns out it bottomed out somewhere n punched a hole in my oil pan and my motor is toast...so im on the hunt for another 5.3 now
That sucks. Since you need another motor now, think it would be easier to swap all your ls stuff straight over to the 83 n use its frame?
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
Yeah actually my buddy who helped me build the 74 said we should just do that instead...btw what gear ratio does an 83 have? My 74 has 3.08s at the moment but would like 3.73s or something
Heres the new truck
Another pic
Yes. Always use the frame bushing kit regardless of cab. Ivorton the only best way to find out is pull the cover and count. Plus you can inspect what you're working with.
#13 |
Moderator
![]() Join Date: Oct 2008
What does the SPID say?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#14 |
The RPO says GQ1 standard rear axle...theres no other codes. I dont know if its a 10 or 12 bolt rear end....ill have to look n see
#15 |
Moderator
Get the 1985 vehicle information PDF from the GM Heritage center. You can look up the standard axle ratios based on series (10, 20, 30), 2wd or 4wd, Engine, and transmission.
https://www.gmheritagecenter.com/gm-...tion-kits.html
#16 |
Looks like it might be a 2.73...will be swapping in the 3.08 from my 74
