Old 10-31-2016, 07:46 AM   #1
MikeCofield
What finish did you use on the bottom side of you floor pan ?
Looking for ideas on what others have used for finish on bottom of floor pan on blazer during restoration. Any ideas or pics greatly appreciated
MikeCofield is offline   Reply With Quote
Old 10-31-2016, 09:01 AM   #2
69-72
69-72's Avatar
Re: What finish did you use on the bottom side of you floor pan ?
Raptor liner on top of por15
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 10-31-2016, 09:58 AM   #3
flashed
Mine got a good undercoating ,dont remember what kind .
flashed is offline   Reply With Quote
Old 10-31-2016, 11:09 AM   #4
hemi43
hemi43's Avatar
Epoxy over bare metal then painted with satin black urethane single stage.
hemi43 is offline   Reply With Quote
Old 10-31-2016, 03:46 PM   #5
Chad22873
Chad22873's Avatar
Raptor liner on top of Por15. Worked out great for me and looks good.
BR549
Chad22873 is offline   Reply With Quote
Old 10-31-2016, 04:28 PM   #6
72 paul
Say 69 72,curios as to bottom of box panels I see two drain holes.Were those oem and you drilled an xtra hole?
72 paul is offline   Reply With Quote
Old 10-31-2016, 04:30 PM   #7
69-72
69-72's Avatar
That's the way they come. I have another blazer that has the holes as well
Old 10-31-2016, 04:42 PM   #8
72 paul
Thanks for your reply.Just realized what I did to bottom of mine.Wont hurt none though.Gettin ready to seal mine up to.Not sure on product yet myself.Not meaning to steal your thread Mike.
Old 10-31-2016, 08:37 PM   #9
tristan
U-POL on the bottom of the floor, POR-15 on the rocker boxes, frame and bottom of fender wells.
tristan is offline   Reply With Quote
Old 01-10-2017, 12:42 AM   #10
Stokester
I used lizard skin ceramic undercoating. I'm not putting carpet back in so I needed something to keep it cooler. They say 20+ degrees difference. I did firewall also. Really happy with how it looks.
72 blazer 4x4 4" 35's
02 f150 work truck
15 f350 super crew long bed 6.7 4x4(stock but loaded)
02 f350 horse hauler 7.3 (need to sell)
Stokester is offline   Reply With Quote
Old 01-10-2017, 01:08 AM   #11
elkniks
elkniks's Avatar
epoxy primer, 3M Body Schutz
elkniks is offline   Reply With Quote
Old 01-10-2017, 09:42 AM   #12
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
epoxy sealant, then Cool Car Ceramic
Tom Vogel is offline   Reply With Quote
Old 01-11-2017, 01:14 AM   #13
tjsblazer
tjsblazer's Avatar
I used OEM rocker guard over the epoxy primer. Then painted it in single stage paint in body colour. Pictures in my build thread although the texture appears a lot stronger in the picture from the lighting than it actually has.
As far as I know from the factory the General painted them factory body colour and then sprayed a black anti-chip type material is key areas.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 01-13-2017, 05:17 AM   #14
mcmlxix
Collector of Projects
mcmlxix's Avatar
Line-X
Rich
1972 K5 Blazer CST Click HERE
Old 01-13-2017, 12:12 PM   #15
suville
suville's Avatar
Ya'll might wanna check out (spraylinings.com) you have way more options than with others, You can have a smooth or rough texture I went smooth so it shouldn't hold dirt, oil/grease and road grime way easer to wash and clean. Talk to Randy Lutz
suville is offline   Reply With Quote
Old 01-20-2017, 09:57 PM   #16
MIKE77z
MIKE77z's Avatar
Epoxy primer top aND bottom then lizard skin sound Deadener and thermal inside and box liner on the bottom that damn rust can go to hell and stay away.
MIKE77z is offline   Reply With Quote
Old 01-27-2017, 03:55 PM   #17
BIG ORANGE
BIG ORANGE's Avatar
I had mine media blasted then I sprayed epoxy primer on then went in behind that and shoot it with Rocket bedliner kit.....
Should be around when my grandkids , grandkids are here!!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
