Old 10-31-2016, 08:12 PM   #1
James Pierce
Active Member
327 Harmonic balancer
Rebuilding a 327 and noticed there is no bolt or threads in the crankshaft that holds the balancer in place. I check a 350 on an engine stand nearby and it has a 1 1/2 fine threaded bolt and a 1/4 inch washer on the crankshaft holding the balancer and pulleys in place. Is this supposed to be?
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4WD 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
71 GMC Supr 350 Auto
70 C10 350 Auto
67 CST 327 Auto
James Pierce is offline   Reply With Quote
Old 11-01-2016, 09:07 AM   #2
Jrainman
Jrainman's Avatar
Re: 327 Harmonic balancer
Yes your 327 Harmonic balancer was pressed on, nothing unusual about it
Jrainman is offline   Reply With Quote
Old 11-01-2016, 11:18 AM   #3
James Pierce
Active Member
Thanks jrainman I have not worked on a 327 before and thought the missing bolt was odd. Very simple explanation.
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
70 C10 350 Auto
67 CST 327 Auto
Old 11-01-2016, 02:28 PM   #4
demian5
demian5's Avatar
Ive been driving my 64 impala SS for 10 years now with a press on one for the rebuild with no issues.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-01-2016, 02:29 PM   #5
100%Chevy
If I remember correctly,the high performance engines got the bolt.
In 67,I believe all small blocks got it.
My original 68,C-10 with 327 has the bolt in it.
Mike.
100%Chevy is offline   Reply With Quote
Old 11-01-2016, 07:41 PM   #6
James Pierce
Active Member
Hmmm! The 327 engine I am working on is a 69 with a 68 date code. Then I check a 69 with a 307 and it has no bolt. All the 350 4 bolt blocks I checked have a bolt. Interesting.
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
70 C10 350 Auto
67 CST 327 Auto
Old 11-01-2016, 09:38 PM   #7
clay68c10
clay68c10's Avatar
As I recall, most of the small journal motors had press on balancers. They usually had short water pumps too. I think 67-68 were the cross over years where you could get either style.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-02-2016, 09:56 AM   #8
Jrainman
Jrainman's Avatar
Yes small journal ( Steel crank ) got the pressed on , large journal (cast crank ) got bolted
