Old 10-31-2016, 08:30 PM   #1
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
Dana 60 inner wheel bearing
I am replacing the bearings on a Dana 60 front axle I got from a 1985 Chevy truck. The inner wheel bearing that I removed was a Timken 387-AS. The bearing that came in the kit from Yukon is Timken 387-A. According to the Timken website they both have a bore of 2.25". I can't get the new bearing on the spindle all the way on by hand. I probably could with some taps with a hammer. Is this normal?
1964 Chevy Suburban 4x4
1966 GMC Suburban 4x4
Baketown Scotty is offline   Reply With Quote
Old 10-31-2016, 09:58 PM   #2
obijuan
Re: Dana 60 inner wheel bearing
New bearings require a little persuasion to ramp onto the spindle. But, your inner race has the same bore but different height. One is used to push the hub further out so you can run 35 spline shafts without the shaft rubbing the cap of the lockout.
The taller race is the d60 carrier bearing race btw.
obijuan is offline   Reply With Quote
Old 11-01-2016, 12:18 PM   #3
Baketown Scotty
Junior Member
So I should go ahead and use some force to get the bearing (hub) installed? Thanks for the reply.
Old 11-01-2016, 01:53 PM   #4
obijuan
Force as in a couple whacks with a deadblow yes.
It is heavy and hard to get square on the spindle but once it's slips on it slides great. Don't go crazy. Make sure it's as close to square as possible and pick it up a little.
Old 11-01-2016, 11:16 PM   #5
Baketown Scotty
Junior Member
Guess I should not be so cautious. Rubbed a little ice on the spindle and it slid right on. Thanks for the input. Now I just need to find a socket with the four tabs so I can preload properly.
Old 11-14-2016, 11:12 AM   #6
Orange Crate
Orange Crate's Avatar
The correct sockets are readily available at your local parts store. I think I got both (D60-4 pin & 14B-6 pin) at my local.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 11-14-2016, 03:33 PM   #7
Baketown Scotty
Junior Member
Great. Thank you for the information. I am working in Visalia right now. I stopped in and talked to Kevin at Valley Off Road. He let me borrow his 4 pin socket. Very nice guy.
