Old 11-01-2016, 07:23 AM   #1
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Hydro booster brake problem
I am having a strange problem with my hydro boosted brakes on my 7.4 liter, when the truck is cold the back brakes tend to lock up for the first couple times I step on the brake, but after that work just fine, and it only does it going forward, has anyone had a problem similar to this before. I am new the hydro boosted brake system so I am at somewhat of a lose to figure out the problem.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 11-01-2016, 03:21 PM   #2
DieselSJ
Re: Hydro booster brake problem
The overall braking system is no different between a vac assist booster and a hydro assist booster. The only difference is how the extra boost is introduced between your foot and the master cylinder. From the master cylinder to the wheels there is no difference between the systems.
DieselSJ is offline   Reply With Quote
Old 11-02-2016, 11:46 AM   #3
Bluestep
Jeff, before you start looking at the hydroboost, look at the basics. Pull the drums and inspect the brakes. A leaking axle seal can cause these symptoms. If the seals are leaking be sure to inspect and clean the rear axle vent. The vent being plugged is often the cause of leaking axle seals.
Bluestep is offline   Reply With Quote
Old 11-02-2016, 12:51 PM   #4
TexasJeff
TexasJeff's Avatar
Thanks guys I was not sure if there was any difference between the Hydro and a normal power booster brake system. I will look into all that you suggest.
TexasJeff
