Old 11-01-2016, 07:28 AM   #1
Tomo
Hard top removal - permanent hardware in fiberglass
My guess is this has been discussed before but I'm unable to find the thread. Has anyone drilled holes in their double wall top and used eye bolts to remove it like in the pic below? This is a late 70s/80s k5 with a half cab - think this could work for a first gen?
Here's more info on the set up: http://ck5.com/forums/threads/a-bett...ardtop.240634/
Tomo is offline   Reply With Quote
Old 11-01-2016, 09:42 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Hard top removal - permanent hardware in fiberglass
Tom Vogel is offline   Reply With Quote
Old 11-01-2016, 09:59 AM   #3
Tomo
Originally Posted by Tom Vogel View Post
Not a fan? It doesn't always have the eye bolts sticking out. On a 4x4 I don't think you would ever see this hardware. My main concern is will 4 anchor points be enough to lift a double wall top without ripping through the fiberglass - Kinda guessing this will be the case. Here's the hardware:
Old 11-01-2016, 12:47 PM   #4
Tuff Gong
Tuff Gong's Avatar
Just throw a few 2x4s under it and hoist it up. Not worth modifying the top in my opinion.
Tuff Gong is offline   Reply With Quote
Old 11-01-2016, 01:18 PM   #5
truckster
truckster's Avatar
Halloween prank, maybe?
truckster is offline   Reply With Quote
Old 11-01-2016, 01:19 PM   #6
OldBalls
OldBalls's Avatar
Here's my rig, works fine.
OldBalls is offline   Reply With Quote
Old 11-01-2016, 02:43 PM   #7
Tomo
My concern with this method is scratching the paint (Once I get to that point) - probably making it out to be a bigger deal than it really is.
Old 11-01-2016, 03:12 PM   #8
hemi43
hemi43's Avatar
I'm thinking more like April fools !
hemi43 is offline   Reply With Quote
Old 11-01-2016, 03:37 PM   #9
OldBalls
OldBalls's Avatar
Ya I agree on the paint issue. This guy built a frame above the top which is my plan...
http://public.fotki.com/blazbk/blaze...oof/page2.html
Old 11-01-2016, 03:57 PM   #10
Tomo
That looks great - thanks for the info. I'll probably end up doing something like that too.
Old 11-01-2016, 04:13 PM   #11
Tuff Gong
Tuff Gong's Avatar
I used (4) separate straps so they don't even touch the top.
Old 11-01-2016, 04:17 PM   #12
OldBalls
OldBalls's Avatar
Looks good!
Old 11-01-2016, 06:22 PM   #13
Tomo
Delete
Old 11-01-2016, 06:44 PM   #14
dirish
dirish's Avatar
Originally Posted by brian atkinson View Post
i used (4) separate straps so they don't even touch the top.
x2
Dbl 2x4s on top straddling trusses. Single 4x4s on bottom. ONE strap on each corner. I added a steel tether in case of strap failure.
dirish is offline   Reply With Quote
Old 11-03-2016, 12:43 AM   #15
Blazerowner
Blazerowner's Avatar
I think cracking the top would be a possibility with those eye bolts attached directly to the top. I can see the reasoning but the top is pretty heavy. I went with the 2x4s like others and lifting up each corner to put the chain on the bolt took a bit of strength. I would say if you did go that route there would need to be some large bracing on the underside. You may get bowing as well since there isn't support for the sides.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 11-03-2016, 02:29 PM   #16
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
That was the 1st version.
Here is the 2nd version.
Link to the build.
http://public.fotki.com/blazbk/blaze...g-the-roof-to/
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 11-03-2016, 02:34 PM   #17
BobbyK
BobbyK's Avatar
Here it is in action.
https://www.youtube.com/watch?v=4X-flPMbAxE
