Electric trailer brake controller???
Greetings,
I did a search for trailer brake controller, and found a lot of good information. Ive been shopping for a trailer brake controller. I know the ones they use now are inertia type. Id like to use the old hydraulic style. Dose anyone know if they are still available? Thanks for all replies |
![]() Join Date: May 2016
Re: Electric trailer brake controller???
Friend of mine had one put on his boat trailer. Not sure if it was used or new. I'm sure someone can chime in on this.
I wouldn't. Not towing anything for any distance.
For show and a short town, maybe, but I had one in my 74 3/4 BB burb and it leaked and needed to go.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Post Whore
![]() Join Date: Feb 2016
What kind of brakes does your trailer have? Hydraulic brakes are self contained and have no controller on the towing vehicle. They use movement in a special coupler that applies the brakes. Simple but you have to get out of the rig to lock it when backing up and then get out and unlock after backing. Electric brakes have a controller in the towing vehicle. If your towing with a newer rig (last five years or so) the controller may be already be installed and interacts with your vehicle's electronic control package. These work very nicely.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
HO455, I don't think my 1969 C-10 has an electronic control package. I don't have a trailer yet, but it will be equipped with electric brakes, which will be controlled from my pickup. I want the trailer brakes to be applied proportionally, when I press on the brake peddle. The harder I press on the peddle, more voltage to the trailer brakes. The old Kelsey-Hayes type had hydraulics from the master cylinder routed to the controller. Like demian5 had on his 74 suburban. The controllers I've found so far, use an inertia switch to activate (send voltage to) the trailer brakes.
ive got the style you are looking for, and I also have some newer electric controllers in my newer trucks. The newer electric controllers work just fine in my opinion, and then you dont need to bother with plumbing a hydraulic line into the cab.
I think my electric ones are voyagers and they have worked great for several years now, no issues once you set them up after installation. |
Ak808, are the ohydraulic style you have new, or new old stock? I've seen the voyager, and think it would be fine on newer vehicles with power disc brakes. I think with my old non power drum brakes, the trailer brakes would work best being activated by the peddle. Seems like the old style had a sensitivty adjustment which would allow the trailer to provide more braking than the tow vehicle.
It was in the truck when I bought it, but I dont think it was a dealer item.
The electric controllers are pretty fancy nowadays. They are reasonably cheap, and even with drums, I think you are going to find they work just fine. The controllers can be adjusted for both sensitivity and braking force. I think you can find a setting that will work just fine for you. |
Post Whore
I'm sorry I didn't realize you were referring to an electric over hydraulic system. My bad. They are kinda pricey. The only one I have ever seen was on a eight horse trailer that was towed behind a 45 foot pusher. Had it's own hydraulic pump that made pressure for the slave cylinders that was controlled electronically from the pusher. I never saw the controller in the pusher. I do know they are available new and are sophisticated systems.
I am a trailer specialist and everyone that has a hydraulic controller and a new trailer burns up the brakes in the trailer because those don't have a correct voltage for it my recommendation is a CURT tri-flex or discovery controller I have have a trip flex and use it everyday and have no problem at all
Brysen and his trucks 1971 Custom/10 (the big c10) 1970 C/10 (the gold truck) |
Brysenj, thanks for the reply, I'm not sure what type of trailer I may be pulling, chances are it will be something built between 1965 and 1975. If I do decide to buy a new(er) trailer, I will need to do some research about trailer brake voltages. For now I'd like to find the old style, I've found some NOS Kelsey-Hayes on eBay, I'm just wondering if they still make em?
