Old 11-01-2016, 01:08 PM   #1
62KneeKnocker
Used power steering swap for 62
Good afternoon, I'm new to this forum and this is my first build. While this may be my first build, I am mechanically inclined, worked with power tools and welding, repaired my own vehicles for over 20yrs and I'm not afraid to dig into any part of this truck and do what needs to be done to make it they way I want.
I have a 62 C10 LWB Fleetside I am planning out. I don't know if this is a hard topic to find with keywords or not but I can't seem to find any threads on what vehicles I could pull a used power-steering setup from to install in my 62. I run across plenty of threads for "new" power steering kits (new) but I'd like to avoid $1000+ and pull parts if I can from another vehicle.
Has anyone every done this? My 62 is currently stock and I plan to keep the stock front-end suspension with torsion bars.
Chris
62KneeKnocker is offline   Reply With Quote
Old 11-01-2016, 01:54 PM   #2
padresag
Re: Used power steering swap for 62
did you look thru the FAQ section? I think that you will find what you want in there. it is up a little higher in this section
ron
padresag is offline   Reply With Quote
Old 11-01-2016, 11:50 PM   #3
Captainfab
60-66 Nut
Welcome to the forum
You will need a steering box and pitman arm from a '68-'86 C series or '87-'91 R series truck, Suburban or 2wd K5 Blazer. Then of course a steering box adapter plate. I do offer a kit for the '60-'62 frames that requires a little more work than the '63-'66 installation.
http://www.67-72chevytrucks.com/vboa...332923&page=26
