Old 11-01-2016, 01:15 PM   #1
hamjet
hamjet's Avatar
Am I thinking right?
When I try to start my 69 pickum up, it cranks over fast and fine, but won't start. the second I release the key to run position it starts. It doesn't matter if it's hot or cold start. this is something that started acting up for a few weeks, about 90% of the time. nothing new, other than a new key set I installed about six months ago. I believe it's the ignition switch, but before getting one I want to here your opinions. Am I correct in my thinking????
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 11-01-2016, 01:22 PM   #2
B. W.
B. W.'s Avatar
Re: Am I thinking right?
If is still has points then the bypass circuit is open. (the bypass circuit may be open due to a bad key switch!) If it does not have a resistor in the ignition system it is probably the key switch.
B. W. is offline   Reply With Quote
Old 11-01-2016, 02:31 PM   #3
demian5
demian5's Avatar
Confirm with a jumper to the coil from the battery +. If it starts right up, you know the circuit isn't giving the needed voltage as designed. I vote for ignition switch as well.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-01-2016, 10:43 PM   #4
El Dorado Jim
the little wire down on the starter solenoid has probably broken at the terminal, check this first before getting another ignition switch.....i have had this happen
El Dorado Jim is offline   Reply With Quote
Old 11-01-2016, 10:43 PM   #5
El Dorado Jim
let us know what you find out....
