11-01-2016, 06:57 PM | #1 |
spark plug and header question
03 yukon 5.3
im going to run headers and im reading that ill need to run msd wires? how come i would have to change to the msd? they look the same to me and does anyone have any for sale?
1967custom |
11-01-2016, 07:17 PM | #2 |
Re: spark plug and header question
stock GM / AC Delco wires with Doug Thorley Tri-Y's. Works perfectly.
11-01-2016, 08:53 PM | #3 |
meowMEOWmeowMEOW
Some header combo's need the extended plug ends, or the angled ends. It depends on the header, and the size of the primary.
I switched to MSD's because a) they are a nice wire and b) the "multi-angle" boots will fit pretty much any combo.
11-02-2016, 12:49 PM | #4 |
ohh. i cant afford those nice doug thorleys
i was thinking about the nice ones on e bay. speed....something
1967custom Last edited by michael bustamante; 11-02-2016 at 01:23 PM. |
11-02-2016, 04:13 PM | #5 |
I've seen MSD wires recommended because the factory wire boots can sit on the header tubes on some headers. The MSD wires, like BR3W mentioned are adjustable to bend the boot to fit your application.
You could always go another route. I bought the Accel Extreme 9000 Ceramic boot plug wires with 45 degree boots. They're spendy, but after having burned two plug wires on my old SBC, I wasn't going to deal with it again. Had them on the SBC and they worked great.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
11-02-2016, 09:11 PM | #6 | |
meowMEOWmeowMEOW
11-03-2016, 05:03 PM | #7 |
Be careful if you look into these. There are many manufacturers, but most of them (if not all of them) will not fit 90 degree plug boots. I have a set of these that wouldn't fit my wires, so I went the ceramic boot route. If you aren't running 90 degree plug boots, you should be fine with them.
11-02-2016, 06:34 PM | #8 |
cool. thanks guys
1967custom |
11-03-2016, 04:57 PM | #9 |
i have never seen those before... ill look into them
1967custom |
