Old 11-01-2016, 07:36 PM   #1
JWalter 64
Cigarette lighter
When wiring a cigarette lighter, one just runs a wire to the fuse box and plugs it in where it is labeled lighter, correct?
JWalter 64 is offline   Reply With Quote
Old 11-01-2016, 10:46 PM   #2
'63GENIII
'63GENIII's Avatar
Re: Cigarette lighter
Yes. Make sure that the wire size matches the fuse. I think mine was a #14 ga wire with a 10 amp fuse.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-02-2016, 06:12 AM   #3
Mjminino
Yes, it will self ground through the bezel.
Mjminino is offline   Reply With Quote
Old 11-02-2016, 08:15 PM   #4
JWalter 64
Thank you for the replies! I love this board, every one is so helpful
