Old 11-01-2016, 09:32 PM   #1
Vortech
Vortech's Avatar
Intermediate Shaft
I want to use the intermediate shaft and column from a 1971 on my 65 C10. I want to use a U-joint to replace the factory grease knuckle between the steering column and the collapsible intermediate shaft. The collapsible shaft has a pin, sleeve, and a pot. Do i just remove the pin and sleeve and use a 3/4" smooth to 3/4" 36 spline u-joint and use the existing hole to anchor the u-joint? Or do I cut the lower portion where there is a "DD" 3/4 design and use a 3/4" DD to 3/4" 36 spline u- joint?
Vortech is offline   Reply With Quote
Old 11-01-2016, 10:03 PM   #2
B. W.
B. W.'s Avatar
Re: Intermediate Shaft
I would cut the lower portion where there is a "DD" 3/4 design and use a 3/4" DD to 3/4" 36 spline u- joint. This, I believe, is the safest method.
B. W. is offline   Reply With Quote
Old 11-01-2016, 11:56 PM   #3
Vortech
Vortech's Avatar
Makes sense, Thanks. I will install power steering gearbox and steering column before I measure and cut intermediate shaft.
